rod and piston question
Old Jan 29, 2012 | 08:26 PM
stangstomper68's Avatar
Default rod and piston question
So I just got my stuff back from the machine shop the other day. Bought a reman crank had my rods and pistons checked and the block prepped. Well the kicker is I installed my crank today checked it torqued everything to spec. When I went to get the rods to prep them I noticed the numbers of what cylinder they go in wasn't on the bottom of them like it was when I took them to the machine shop. I think it was written with tire marker or something. Anyway does it matter at this point since everything is new which cylinder they go in. I understand the way the rods are made and everything matter and the dot on the top of the piston. Any help would be appreciated thanks.
Old Jan 29, 2012 | 08:33 PM
Mangled03gmc's Avatar
Baltimore Whore
Have the rod bearings been fit for the crank journals yet? If yes, then yes then need to go on the journal that it was sized for. If not it needs to be done, then you can mark them once they have been done for each one.
Old Jan 29, 2012 | 08:36 PM
do you mean as far as checking for clearances with plastigauge
Old Jan 30, 2012 | 09:16 PM
mcfarlnd's Avatar
Un-Registered User
The piston position shouldn't matter. As long as you have the bearings size straight, your good. Unless you have only one journal o.s. and 1 rod journal undersized... Etc.... Even then, it's all about your bearing placement for the rods. Just check your clearances then check them again
Old Feb 1, 2012 | 09:16 PM
its done we are golden. Should be done with the build hopefully tomarrow. Then off to the fun part of putting it in.
Old Feb 1, 2012 | 09:20 PM
TXSZ66AVLANCHE's Avatar
It only takes 4 hours
Old Feb 2, 2012 | 09:42 AM
01silvy's Avatar
depending on skill level and if you have a helper or not
Old Feb 2, 2012 | 09:50 PM
thankfully I have a helper
Old Feb 2, 2012 | 10:36 PM
01silvy's Avatar
oh yeah your golden then.. I see your in hickory, i think thats about 2.5-3 hours from me.. I would have lent a hand if my schedule permitted.. Good luck on the swap and let us know how it goes.
Old Feb 2, 2012 | 10:44 PM
01silvy's Avatar
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
greedygenius
Sep 3, 2015 06:51 AM
USMCvet0311
Aug 1, 2015 07:45 AM
black6spdz
Jul 16, 2015 01:32 AM
