rear main seal
Old May 5, 2022 | 04:49 PM
00pooterSS's Avatar
The OP's leak is probably the cam sensor o ring. I've had a million of those come in puking oil, it leaks right onto the rear main and makes it appear it has a rear main seal leak.
Old Aug 15, 2022 | 07:34 PM
therock's Avatar
@00pooterSS
I hope you are right in my case. I have an L33 that got an 8psi Maggie install @5k miles now with 105k miles. Catch can since the install.
Recently I noticed oil wicking the back of the pan kind of looking like it was coming out the trans inspection plug but its dry in there. Dry TC and starter gear. Not dripping to the floor.
I de-greased the hell out of the area and ran her again a few days and this time I flashlighted finding the point of exit at the starter plastic cover area. This crank shaft sensor is there. You think!?!
Thanks.
Old Aug 15, 2022 | 08:23 PM
00pooterSS's Avatar
Originally Posted by therock
@00pooterSS
Thanks.
as many years are on those seals they probably all need to be replaced.
the cam sensor when it leaks will leave oil on both sides of the motor especially on the plastic close out panels (the plastic covers by the starter and on the other side)
Old Aug 16, 2022 | 03:33 PM
therock's Avatar
Thanks, After posting I researched like I should have seeing no sensors there. Sigh.......... I was hoping for some luck.
Old Aug 18, 2022 | 09:15 PM
terravast4's Avatar
@00pooterSS
Thanks.
. Vent that crankcase
Old Aug 19, 2022 | 10:35 AM
Go5.3tt06's Avatar
update had to use acdelco seal and plate its work no more leak
Old Aug 19, 2022 | 04:02 PM
therock's Avatar
I have a a catch can, not enough?
jclark10
14
Oct 15, 2021 06:02 PM
cj847
Feb 20, 2016 02:13 PM
Tkosinski2
May 16, 2012 09:56 PM
DrX
21
Aug 24, 2011 05:02 PM
charlie_riggs
Dec 10, 2009 01:57 PM
