rear main seal
Old Apr 25, 2022 | 08:15 PM
Go5.3tt06's Avatar
Default rear main seal
3th times replaced that issues. NEW seal, rear gasket, and rtv ......Even I replaced new oil pan gasket as well. Why it still leaking most is on rear main seal. I looked at crankshaft end of journal where seal lip was. It look smooth. Nothing cut or scratch on the journal crank.. Any idea will fix the problem, Im going replace new back plate, seal, gasket to see what happen.
Old Apr 25, 2022 | 08:29 PM
FFDP's Avatar
Excessive crank case pressure can make the rear main seal leak too.
Old Apr 25, 2022 | 08:34 PM
Go5.3tt06's Avatar
what crank case pressure is?
Old Apr 25, 2022 | 09:16 PM
FFDP's Avatar
Based on your Signature you have a turbocharged truck. That turbo charger is what can cause more crank case pressure than normal because if that boost pressure is going past the piston rings it goes into the crankcase. If that pressure can't get out then it can start to push oil past seals.
This is just a guess as to what is happening.
Old Apr 26, 2022 | 09:16 AM
MikeGyver's Avatar
Or backwards through the crankcase ventilation system.
Old Apr 26, 2022 | 11:12 AM
arthursc2's Avatar
Rear main has the largest surface area of any unrestrained gasket in the engine. It's the first to get pushed when the block can't vent sufficiently
Old Apr 26, 2022 | 07:24 PM
theunderlord's Avatar
You need a catch can. All forced induction engines do.
Old Apr 26, 2022 | 09:46 PM
ALL ULL C's Avatar
I’ll second that this is you solution.
Old Apr 29, 2022 | 12:48 PM
ZO6Ted's Avatar
Agree but I am the worst procrastinator in the world I guess. 55 K on mine since the Whipple and I never did but it's somewhere in storage so maybe next fall.
Old Apr 29, 2022 | 05:10 PM
terravast4's Avatar
At least vent the valve covers
