Question on PRC stage 2.5 heads for 5.3
Eventually I am going to build a 5.3 to take the place of my 4.8. However instead of just rebuilding a regular 5.3, I wanted to use flat pistons from a 4.8 for higher compression. At first I would have stock heads, but eventually a set of the PRC's will be purchased.
My question is this: stock compression is 9.5:1 right? Flat-top pistons will raise it to 10:1 correct?
Finally Texas Speed says the heads are designed to raise compression to 10.75:1...with the flat tops this would raise it to over 11:1... can you run this with pump gas? If not, how would one go about lowering the compression while still using the flat tops?
OR is all my math wrong...help me
11:1 or even 11:5 would be fine with pump gas ( 93 octane ) theres a few i know who runs 12:1 without issues on pump gas even 12:5
4.8 pistons in a 5.3 with the stock MLS gasket and the stock 706/862 heads is almost right at 10.3:1 CR. If that helps ya...so if the PRCs are milled any then compression will go up from there... I have this same combo and am about to switch to 243's so i can go down to around 9.9:1 for FI
Choda
Jan 22, 2026 02:03 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
KyleW707
Jul 29, 2015 08:17 AM
