power steering pump pulley
Old Feb 10, 2010 | 07:19 PM
Question power steering pump pulley
I bought a used power steering pump from a salvage yard and the pulley came with the pump but wasn't on the shaft. Inside the shaft is threaded but I can't tell what size bolt to use and was wondering if anyone knew what the thread size is?
Old Feb 10, 2010 | 09:01 PM
MikeGyver's Avatar
Old Feb 11, 2010 | 01:10 AM
Blown06's Avatar
8 Second Truck Club
If your asking this question cause you need to get the pulley off, I would suggest you go to an autoparts store and rent a power steering pulley removal/installation tool. Its usually free and will save you a lot of trouble.
Old Feb 11, 2010 | 06:01 AM
No, I need to put one back on.
Old Feb 11, 2010 | 02:56 PM
MikeGyver's Avatar
Then you need an installation tool. If you try it with just a bolt and washers, the threads will pull out of the pump shaft.
The tool has a bearing that is pushed by a fine thread pusher thing.
Old Feb 13, 2010 | 12:34 PM
Is this some kind of special tool that is going to be hard to find, or will a regular pulley puller work?
Old Feb 13, 2010 | 08:04 PM
Mrgoodwrench3's Avatar
You need to use the installation tool. Don't use a bolt in the shaft. It puts too much stress on the threads, you will ruin the new pump.
Old Feb 21, 2021 | 10:36 AM
Kristy Clark's Avatar
Registered User
I think what he is trying to say is that he needs the boat that holds the pulley on after he uses the installation tool. That's the problem I am having as well. The bolt broke and I thought my pump went out. I replaced the pump and the pulley but can't find a bolt to secure it anywhere
Old Feb 21, 2021 | 10:55 AM
RB04Av's Avatar
5 Year Member
They don't have a bolt. That's probably why you can't find one.
The installer tool is a threaded rod that screws into those threads; then a nut screws down against the pulley, with a bearing to take up the turning force. The corner parts stores "rent" the tool for free. Then when you're through, you take the threaded rod tool out and return it to the store. The pulley will be flush with the end of the pump shaft, and is a REAL TIGHT press fit, such that it doesn't need a bolt at all.
But he was struggling with all that over 11 years ago; I hope he got his figured out sometime since then and it isn't still kicking his butt. Meanwhile, if your pulley is on all the way, then your job is done.
Old Feb 21, 2021 | 12:51 PM
timharber's Avatar
The threads are only used to install the press fit pulley. No bolt is needed after that.
Tim
lxcoupe
Apr 3, 2020 01:57 PM
tim wellington
Mar 27, 2018 09:51 PM
jkade72
Aug 21, 2007 09:03 PM
CoonToot
May 7, 2006 10:11 PM
thunder550
18
Apr 16, 2006 11:32 AM
