Ported heads, what did you use to seal the rocker bolts
Old Sep 8, 2010 | 09:54 AM
BlackGMC's Avatar
Resident Retard
Default Ported heads, what did you use to seal the rocker bolts
Well i have been injesting oil ever since i installed my PRC heads, i am hoping it is just leaking threw the rocker bolt. when i installed them i did not put anything on the bolts... so i am wondering what everyone uses... Also i was planning on cleaning up the rocker bolt holes, would brake clean be OK to use?
Old Sep 8, 2010 | 09:58 AM
00ChevyScott's Avatar
Wearin' da big hat
Wouldn't some green/blue locktight work fine? I know permatex makes a thread sealant as well
Old Sep 8, 2010 | 09:59 AM
BlackGMC's Avatar
Resident Retard
yep those are the two options i was considering... Just wondering if one was better than the other...
Old Sep 8, 2010 | 10:03 AM
Wearin' da big hat
use both? Green locktight on the bottom and thread sealant at the top
Old Sep 8, 2010 | 10:04 AM
BlackGMC's Avatar
Resident Retard
actually i have read about people using both, perhaps i will try that... Hey do yall sell both at oreillys?
Old Sep 8, 2010 | 10:05 AM
Wearin' da big hat
Sure do, it's back with all the rest of the RTV on the shelf.
Old Sep 8, 2010 | 10:06 AM
BlackGMC's Avatar
Resident Retard
cool, i gotta stop by there anyways to pick up some intake gaskets and TB gasket for my new intake ... Might as well address the rocker bolts while i am at it..
Old Sep 8, 2010 | 10:15 AM
Wearin' da big hat
I'd call ahead of time (early today if possible) to see if they have the intake gaskets. If its a NNBS intake you're changing to, they might have to order it in to the store.
Old Sep 8, 2010 | 10:19 AM
Sales2@Texas-speed's Avatar
Former Vendor
We use plain old, black, RTV silicone!
Old Sep 8, 2010 | 11:32 AM
RibeiroBJJ's Avatar
Praise The Lowered
Thats what I used..but the grey GM brand seeing I was at the dealership..
-Also something to consider while your in there ...I used the Edelbrock high flow rocker arm studs on mine... they are shorter so they dont protrude into the runner like oem ones..only $40 too
