Part # for the "improved" PCV valve?
Old Feb 13, 2006 | 05:07 AM
14 Second Truck Club
Default Part # for the "improved" PCV valve?
I think its off of a 6.0 or something, remember hearing something about it awhile back. Thanks
Old Feb 13, 2006 | 05:17 PM
RoninsDenali's Avatar
Do a quick search for LS6 valley cover, and it requires a "late" model block for easy installation. (earlier blocks require some dremel work in the valley to make it clear.)
Old Feb 13, 2006 | 05:36 PM
TURBHOE's Avatar
the dremel work isn't hard i use a die grinder with a cut off wheel on it and you cut a little piece off the block no big deal.
Old Feb 13, 2006 | 09:01 PM
budhayes3's Avatar
PT's Slowest Truck
The part number I have for the re-designed PCV valve is 12572717. It's called a "fixed orifice" PCV valve...it's basically an empty PCV valve with a tiny hole at the bottom (no spring and plunger). FWIW, oil still gets sucked through it....I tested it with my catch can, then switched back to the regular PCV valve because the new one whistled when combined with my AMW catch can.
mhorn0817
Jul 8, 2017 01:54 AM
The_W
Oct 28, 2015 09:00 PM
jroctpb
Aug 11, 2015 03:52 PM
Mzay
Jul 6, 2015 11:05 PM
Mzay
Jul 6, 2015 11:03 PM
