ORY for stock exhaust?
Old Aug 26, 2005 | 11:31 AM
DrX's Avatar
DrX
Default ORY for stock exhaust?
Does anyone make an ORY that bolts up to the stock exhaust systems?
Old Aug 26, 2005 | 02:38 PM
DrX's Avatar
DrX
I assume that is what would be needed for these if I want to retain the ability to replace the cats: http://www.jbaheaders.com/headerdeta...rtNum=1850-2JS
Also, I have seen shorties recommended for the Radix, but is the 1 5/8 tubing size adequate?
Old Aug 26, 2005 | 04:14 PM
Leroy_454's Avatar
The shorties don't gain much power for you. Most people say the stock manifolds are just as good. I would go long tubes, or at least a good mid length.
Old Aug 26, 2005 | 08:11 PM
DrX's Avatar
DrX
If shorties are better than longs(I have been told) but no better than stock, I may as well use stock manifolds with an ORY. 90% of the restriction in the exhaust is in the cats anyway.
GM specs allow for a maximum catback back pressure of .5 psi (measuredat 2000 RPM).
Max allowed precat backpressure is 3 psi. It would appear that there is nothing else you can do with the exhaust that can equate to the improved flow of cat removal.
It would be nice to have a side by side dyno comparison of short/mids to long tubes on a Radix setup.
Old Aug 27, 2005 | 12:01 AM
Leroy_454's Avatar
The shorties are not better than long tubes. The long tubes will yield more low and midrange torque and a horsepower increase throughout the rpm range. The shorties may show a slight gain in the upper rpm range only.
Old Aug 27, 2005 | 12:35 AM
DrX's Avatar
DrX
The physics of that make sense in normally aspirated applications but doesn't the supercharger change the whole equation? Todd@ProDyno says they consistently get their best numbers with short/mids with the Radix. Not sure what diameter pipes they are using.
ARC
57
Feb 21, 2022 10:54 AM
zblee
Aug 3, 2015 03:45 AM
OLD BULL
Aug 1, 2015 05:00 PM
Chiphead
Aug 1, 2015 04:43 PM
GMCtrk
Jul 17, 2015 06:39 PM
