BB thermostat mod
Old Aug 26, 2005 | 11:13 PM
Searching4Sierra's Avatar
Default BB thermostat mod
will the "bb" trick work on a 2001 type thermostat? and does that make it function like a 180* t'stat? thanks
Old Aug 26, 2005 | 11:50 PM
chevyerett's Avatar
I believe it makes it 160*. Mine runs about 180-185 after warm up. With the A/c on it runs about 195-200. Kind of wierd, but it doesn't overheat at all. In the winter it hardly ever gets over 185. And I do believe it will work on the '01 models. In the LS2 I believe they use a thermostat like the old SBs, but with the newer Gen III thermo housings. Not sure...
Old Aug 27, 2005 | 12:21 AM
goshawk23's Avatar
Truck addict
yes it works. i have had one in my truck for almost two years and no problems what so ever.....one of the great ways to save money mods imo.
Old Aug 27, 2005 | 12:27 AM
NoChrome's Avatar
"BB trick" please explain.
Old Aug 27, 2005 | 12:31 AM
goshawk23's Avatar
Truck addict
basically you take the stock thermostat and use some pliers or equivelant to remove the insides. once taken off truck you will see that the insides can be removed. at the bottome of the stat housing there is a protusion that will allow for a bb to be installed in. reinstall the stat parts and replace on the truck.
Old Aug 27, 2005 | 12:36 AM
BigTex's Avatar
You disassemble the stock thermostat and insert a BB in the center hole, then reassemble it. The BB makes it open up sooner, just like an aftermarket thermostat. I made this a few years ago: http://z71.net/tstat.jpg
My SS had a very narrow stem inside the thermostat that wouldn't take the BB. So I just modded a spare older style thermostat and used it. 2+ years later, no problems.
Old Aug 27, 2005 | 12:44 AM
NoChrome's Avatar
Awesome! Cheap mods are my favroite. Got somthin to do this weekend, anybody got a bb layin around?
Old Aug 27, 2005 | 12:50 AM
FarmerBeau's Avatar
Sexy Party Mod
BigTex, what does your truck run at normally with the BB mod?
Old Aug 27, 2005 | 12:52 AM
BigTex's Avatar
Mine runs in the 185 range without the AC on, before it was a good 205 without the AC.
madmann26
Apr 29, 2020 09:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
bisqikss
Sep 27, 2015 09:40 PM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
