Need some info.
Old Feb 17, 2004 | 06:22 AM
2003blue5.7's Avatar
Default Need some info.
Ok well all know "or should" that putting a ls1 motor in our trucks is a easy swap. But I have a question has anyone put a vette or camaro pcm in? I am useing my 5.3 pcm and a dyno shop told me that there are peramiters that are different between the two? I'm wondering if it's going to be a big deal if I just get my stock pcm tuned. or should I go with the vette or camaro pcm.
Thanks guys
Old Feb 17, 2004 | 06:32 AM
red53gmc's Avatar
There's no difference in the pcm's as far as I know. The only difference would be programming...i.e. electric fans, cags, t56....
Get your truck pcm tuned and you will be fine.
Old Feb 17, 2004 | 09:15 AM
ktmrider's Avatar
I agree, tune the 5.3 computer. One possibility is finding a good Vette/Camaro tuner in your area. This is what I am planning to do in a month or so when the 5.7 "iron" block motor is ready.
Old Feb 17, 2004 | 11:58 AM
why would you want an iron block?
Old Feb 17, 2004 | 12:19 PM
6gear's Avatar
Thanks guys
Use your stock PCM and get it tuned, I used my stock 4.8 PCM and had Nelson tune it and it works fine.
Old Feb 17, 2004 | 04:45 PM
red53gmc's Avatar
Sounds like he's just boring out the 4.8/5.3 block to 5.7 specs.
Old Feb 17, 2004 | 09:06 PM
BOO HOO BRIAN's Avatar
PSJ Wannabe & Attention Whore
The source code if diffrent, thats it. You can make a truck pcm do anything that an f car or y car pcm can do.
I have the truck software from 01 up. Its as easy as anything to tune.
Old Feb 17, 2004 | 09:49 PM
Brian How much is it for a dyno tune? I'm about 45 minutes from you.
slimchevy2
Oct 4, 2015 08:02 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
11MPG
Sep 8, 2015 04:52 AM
