Need help with nelson fan harness
Old Aug 7, 2005 | 01:20 PM
5.3litre's Avatar
Default Need help with nelson fan harness
ok im installing a nelson fan harness and it says to locate pin #42. and put a wire in it..i got my pcm apart but how the hell do you know which pin is #42...thanks!
Old Aug 7, 2005 | 01:52 PM
ZDEN's Avatar
once you remove the plug, look where the wires go into the plug. the #'s are labeled on the plug
Old Aug 7, 2005 | 02:06 PM
5.3litre's Avatar
thanks alot..im blind..i found it
Old Aug 7, 2005 | 02:10 PM
thunder550's Avatar
High on diesel fumes
Make sure you get that pin pushed allllll the way in. I thought I heard it click, but I really didn't. I had to unfold a tiny paperclip and is it to jam the pin all the way into the socket. 2+ hours of troubleshooting later, I still didn't have a working set of fans. Then I took apart the PCM parness again and realized the pin wasn't all the way in.
Old Aug 7, 2005 | 06:43 PM
5.3litre's Avatar
another question i have is im not sure how to wire the fan motors to the harness..they are flex a lite fans...on the back of the motors there are to wires per motor..i have the wires on each motor connected and a wire wired to them that used to run to the vsc..its like this on each motor..how do i wire this to the nelson harness...thanks!
Old Aug 7, 2005 | 08:15 PM
5.3litre's Avatar
also if i turn on the a/c will the fans come on if it isnt tuned yet? i wanted to test them by doing this but its not tuned yet..and can anyone answer my question about wiring the fan motors? thanks!
Old Aug 7, 2005 | 09:54 PM
5.3litre's Avatar
i guess no one knows?
Old Aug 7, 2005 | 10:06 PM
closet red neck's Avatar
You take the blue and the black to one fan motor and connect them to the black and red wires of the harness that are taped together. Then do the same for the other two. Blue is your hot on the fan motor and black is your ground. So, Blue to red and black to black...Hope this helps....
Old Aug 7, 2005 | 10:09 PM
Yes the fans will come on withuot the tune. When the A/C cycles on and off your fans will also cycle on and off.
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
Silver8ado
Sep 30, 2015 11:42 AM
StrokeTheLS
Sep 29, 2015 08:33 PM
old motorhead
Sep 29, 2015 08:22 PM
