Need help with nelson fan harness
ok im installing a nelson fan harness and it says to locate pin #42. and put a wire in it..i got my pcm apart but how the hell do you know which pin is #42...thanks!
Make sure you get that pin pushed allllll the way in. I thought I heard it click, but I really didn't. I had to unfold a tiny paperclip and is it to jam the pin all the way into the socket. 2+ hours of troubleshooting later, I still didn't have a working set of fans. Then I took apart the PCM parness again and realized the pin wasn't all the way in.
another question i have is im not sure how to wire the fan motors to the harness..they are flex a lite fans...on the back of the motors there are to wires per motor..i have the wires on each motor connected and a wire wired to them that used to run to the vsc..its like this on each motor..how do i wire this to the nelson harness...thanks!
also if i turn on the a/c will the fans come on if it isnt tuned yet? i wanted to test them by doing this but its not tuned yet..and can anyone answer my question about wiring the fan motors? thanks!
Wrecker 426
Sep 30, 2015 09:39 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
