Need help Fast!!!! E-fan install issues
Old Oct 22, 2008 | 08:50 PM
SmokinHot98's Avatar
Default Need help Fast!!!! E-fan install issues
I just installed my LS1 efans w/a Nelson performance harness. The truck wants to and is dying everytime the fans kick in. What could be wrong? I installed the grounds, pos, #42 pin, and connected it to the green wire in the loom. I don't get it. Please if anyone can share some opinions I would greatly appreciate it. If this don't work I have to install my clutch fan again and its already 8:50pm
Thanks
Nick
Old Oct 22, 2008 | 08:52 PM
Derek @ EDO's Avatar
FormerVendor
disconnect the green wire in the loom and let us know if that solves your problem.
Old Oct 22, 2008 | 08:55 PM
NegraRCSB2X4auto's Avatar
did you use the dark green wire or the lighter one?
Old Oct 22, 2008 | 09:20 PM
Dark one
well I kinda caught my own mistake with trying to rush with time and only a mag light at my source of light. Everything was hooked up correctly .......but i never put the intake tube back on so the MAF was reading anything thus the engine was choking ou and dying, lol. After I put that on shes's running fine and the fans kick on as they should.
Thanks you guys for responding though, I REALLLLLLLY appreciate it
Old Oct 22, 2008 | 09:49 PM
love it when it's simple mistakes.
I'm in the middle of a cam and head swap myself I bet I'll have something come up too.
Old Oct 22, 2008 | 10:32 PM
haha i just finished doing a head/cam swap on my bros camaro. Everything looked good and when i fired it up it kept on dying and it didn't run right. i could barley pull the car out of the garage without it shutting off. The coil packs ended being up on opposite sides and didn't have a ground on. After that it worked fine.
Choda
Jan 22, 2026 02:03 PM
zblee
63
Jun 10, 2023 01:25 PM
LCHEE
Oct 24, 2020 04:10 PM
thunder550
Oct 8, 2015 04:53 PM
