Need help asap!!! header bolt wont go in...
Old Jul 1, 2010 | 05:50 PM
Medic/Z28's Avatar
Default Need help asap!!! header bolt wont go in...
I was replacing the passenger side header gasket. The second bolt from the front wont go in. It only goes in 2/3 of way. What do I do now? Should I add washers to it and call it a day? Im at work and need to get home.
Old Jul 1, 2010 | 05:53 PM
skeet's Avatar
check and make sure the hole is cleaned out by running the proper tap in..
Old Jul 1, 2010 | 06:02 PM
Medic/Z28's Avatar
How can I clean the hole? WD40?
Old Jul 1, 2010 | 06:05 PM
SweetS10V8's Avatar
With a tap, just like skeet already mentioned.
Old Jul 1, 2010 | 06:06 PM
Medic/Z28's Avatar
Im sorry. Im not sure what that is? Actually I dont know what that is.
Old Jul 1, 2010 | 07:07 PM
Medic/Z28's Avatar
How does the tap work? Can I get it from Home depot? I stuck in the middle of nowhere.
Old Jul 1, 2010 | 07:20 PM
Medic/Z28's Avatar
Is the head trash cause of this bolt thing?
Old Jul 1, 2010 | 07:24 PM
Medic/Z28's Avatar
Ok well I guess Ill get a ride home. Could someone just chime in and explain this please
Old Jul 1, 2010 | 07:37 PM
aaronmc's Avatar
This is a tap
It cleans out threads as well as fixes damaged ones. Make sure you buy the right size or else all you'll do is more damage.
Old Jul 1, 2010 | 07:58 PM
1Bear's Avatar
Thread size: M8 X 1.25
Drill Depth (maximum): 0.826
Tap Depth (maximum): 0.629
