my 383 build thread
Old Sep 18, 2012 | 09:00 AM
  #211
greasemykey's Avatar
Today i bought the map sensor and starter. Going to find out soon if it will start and run. Then its a few week wait until i can afford dyno tuning. I have been without my baby since februrary. Im getting frustrated and impatient.
Old Sep 18, 2012 | 09:51 AM
  #212
swift700's Avatar
Hey, glad to see you haven't given up. Do you have a baseline tune for it to at least get it to start? Do you have a tuning program?
Old Sep 18, 2012 | 03:36 PM
  #213
Wheatley safe tuned it for me to drive on a trailer and break it in
Old Sep 18, 2012 | 04:08 PM
  #214
Good luck hopefully it'll start and run for you today.
Old Sep 21, 2012 | 11:31 AM
  #215
O'Riley blessed me with a bad starter. Or im having electrical fire grimlins. Any thoughts as to where i should start? Relay is good and ignition fuses are good. I have 12.7 volts at the battery. I need to check at the starter still.
Old Sep 21, 2012 | 02:15 PM
  #216
oakley6575's Avatar
What is it doing exactly. Just not cranking at all?
Old Sep 21, 2012 | 03:40 PM
  #217
1FastBrick's Avatar
Custm2500's Rude Friend
To test the starter, Go straight from the battery with power and ground and jump the starter motor to see if it works. I recommend having both out of the car and testing it. Also make sure you hold the starter firmly with something. The torque the produce is very strong.
Then see if your getting power at the wire that attaches to the starter. If not trace back from there accordingly.
Old Sep 22, 2012 | 12:05 PM
  #218
yeah its not doing anything. but im starting to think that i may have a bad neutral safety switch. i replaced that the day i did the starter and with the old starter it at least tried. but i changed the starter and the neutral safety and now i have nothing. not even a click.
Old Sep 23, 2012 | 01:39 AM
  #219
swift700's Avatar
So you tried jumping the starter directly from the battery?
Old Sep 23, 2012 | 01:41 AM
  #220
1FastBrick's Avatar
The neutral safety Switch could cause that if its not properly aligned. But you should check the starter first and make sure it functions properly.
