Motor Upgrade
Old Jun 17, 2007 | 10:01 AM
tahoebigah's Avatar
Default Motor Upgrade
I have a 02 tahoe with 5.3 and I am planning on putting a headers ,cam, rockers, push rods, and lifters in it. I was wondering what products I should use because I am new to this. Well any help would be great and thank you in advance.
Old Jun 17, 2007 | 10:42 AM
silent1's Avatar
It looks like you might have a lift on you're tahoe? What are some more details on your truck, it's main use, towing, off-raod, etc? As for headers, most are going with coated pacesetters because of price and performance, they're a DEAL! Don't bother with rockers for now, just concentrate on cam specs. Where/what RPM range is most useful to you?
Old Jun 17, 2007 | 10:56 AM
nightrunner's Avatar
Mr. Obvious
we have a full roller setup on our valvetrain so no need for aftermarket rockers or lifters on just a cam swap
if going with single exhaust, id suggest a pacesetter ORY to go with the pacesetter long tube headers
you need a cam, valve springs, pushrods, and probably upgrade to a LS2 timing chain and maybe even a ported ls6 oil pump
the cam really depends on where you want your power and how you use your truck
Old Jun 17, 2007 | 12:45 PM
tahoebigah's Avatar
I just want it as a daily driver/hell raiser. I am lookin for just a all around peformance gain. What kind of sprinds, pushrods, and cam do yall think? On the cam I want agressive/performance but not a big lope like a big block.
LIST
Pacesetter long tubes
ls2 timing chain
ls6 oil pump
Old Jun 17, 2007 | 01:37 PM
Mr. Obvious
you can get a ported verison of the ls6 oil pump and TSP (texas speed and performance - sponsor to the right)
http://www.texas-speed.com/shop/item...d=151&catid=55
if you dont get the pacesetter ORY, you will need a custom mid pipe( y pipe xpipe hpipe or true straight duals)
depending on cam you can either get by with ls6 springs or you might need some comp918 springs, or if you get a HUGE cam(not likely) get patroit dual golds
http://www.texas-speed.com/shop/item...d=211&catid=48
http://www.texas-speed.com/shop/item...d=208&catid=48
you need some hardened pushrods, TSP has some hardened chromemoly pieces (7.4")
http://www.texas-speed.com/shop/item...d=152&catid=51
an LS2 timing set is a great upgrade
http://www.texas-speed.com/shop/item...d=621&catid=53
it sounds like something on the order of a comp 216/218 is what would suit you more
Old Jun 18, 2007 | 08:06 AM
tahoebigah's Avatar
I forgot to mention this, it is ok that my motor has 160k miles?
Old Jun 18, 2007 | 04:20 PM
Mr. Obvious
no but def. get the timing chain, oil pump and pushrods with a high mileage motor
Old Jun 18, 2007 | 04:30 PM
xlcooplx's Avatar
i'd do a 212/218 comp if i were you. sure, its a smaller cam but you're driving a brick with large tires. it would suit your ride imo. you could also use ls6 springs for this.
Old Jun 18, 2007 | 05:12 PM
ramdaspadhye's Avatar
Do a 6.0 swap...save you a lot of re-doing later on...
Old Jun 19, 2007 | 10:26 AM
Tootall's Avatar
how about the transmission. . . . it's not going to like your foot either.
OHsixLS3
Dec 27, 2016 09:30 AM
TXsilverado
Nov 26, 2015 10:54 AM
07NBSChevy
Aug 9, 2015 12:59 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
