Question on changing 2-4 band in 4l60e
Ok guys, i have a 2007.5 4L65E and will be removing the motor to do a cam swap and was wandering if it is possible to change the 2-4 band if i remove the pan and pump assembly. There is nothing wrong with my 2-4 band, would just like to upgrade to the Alto Extra Wide Carbon band.
Thank you for the quick reply, i kinda figured the drum would need to be replaced. There goes that option. What about replacing it with a New OE band, would the current drum be ok?
I currently have the Sonnax Smart Shell and Smart Tech housing kit with input shaft. I completely went through the trans at 90k miles. Not due to going bad, just for longevity reasons. It pretty much has every Sonnax upgrade along with the Transgo shift kit. I will be removing the pump to add a Sonnax Heavy Duty pump spring which i didn't add before. I did unfortunately put OE clutches, Steels and Band in it. I ran out of money on it then lol. I will check them while it is out. I would like to put an OE band in it again at the very least. I have 115,000 miles on it now. The trans has never missed a beat and would like to keep it that way since i will soon be having roughly 410HP/410TQ at the crank when i do the cam swap. I really didn't want to take it all apart since i will only have 2 days to get it back together when i do the cam swap since it is my Daily.
