Motor Build-up...some questions
Old Aug 1, 2006 | 01:56 AM
  #21
14 Second Truck Club
I don't see a problem with the 98' blocks personally. It's not like I'm going all out and it's going in a drag car. I understand the problems with the 98' blocks and appreciate the concern. If I was to buy a new block, it for sure wouldn't be a 98'. I bought the longblock for $450, it was pulled because of a few bad valve seals with ~89,000-90,000 miles on it. I was originally looking for a good 6.0 longblock, either LQ4 or LQ9. My original plans with the LS1 was a mild h/c LS1. I was gonna replace all the seals, gaskets, bearings, rings, etc. I started thinking that the jump from a 325ci to a 346ci wouldn't give me the extra torque I was looking for. So, I finally decided on building something a little bit bigger than the 364 I was originally looking for, hence the 383.
When I started buying parts for the 383, I wanted a mild stroker set-up that would put down at least 400rwhp/425rwtq and have a bunch of under the curve power. It should drive very good on the street with a Yank 2600. Hopefully at the track, it'll be good for high 12s with slicks. I'll be running the truck intake for awhile, but plan on swapping to a ported LS6 after the first of next year.
Old Aug 1, 2006 | 01:34 PM
  #22
Quik's Avatar
5 year bitches!
your plans are good but youll have more money into a 383 stroker then you would need to make 4xx/4xx RWpower. a nice 6.0 will put those numbers down. a 346 has put those numbers down many times
personally 5xx/5xx is the goal for a stroker anything less i wouldnt bother
Old Aug 1, 2006 | 02:54 PM
  #23
twobit's Avatar
Looks like a nice build up Richard. Glad to see it coming along for ya.
Old Aug 1, 2006 | 03:59 PM
  #24
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Seriously thats alot of money when you could have just slapped a radix on or turbo and had that power. You are selling yourself short IMO.
Old Aug 1, 2006 | 04:16 PM
  #25
Quik's Avatar
5 year bitches!
yea seriously, but a cam and heads would get you that power with right tune on a 6.0. alot less then a blower. just a little less driviably
Old Aug 10, 2006 | 09:33 PM
  #26
clean03's Avatar
Default hey hemi kiler
hey hemi killer i noticed u have a crank and all that stuff for pretty much a full long block build.u have crank rods piston heads block and ll and u said 2000$. well im addin my parts to list to make it happen and at my price it seems a lil out of range for a while like 5-6 grand. if u dont mind me askin where u got every thing please help me out cuz at this rate my 4.8 gunna have to somehow go alot farther but im not positive it will. thanx man
Old Aug 11, 2006 | 07:08 PM
  #27
litreddevil's Avatar
Banned
Just ordered $2000 in parts for my motor build-up. Here's what I've got or have ordered:
-98' LS1 Block
-4.000" Eagle Crank
-Scat 6.125" H-beams
-Mahle Forged Pistons -6cc dish (3.903" Bore)
-Patriot Performance Stage II 5.3 Heads
-F13 Cam (230/232-.595/.585-114)
-Durabond Cam Bearings
-Clevite "H" Rod & Main Bearings
-ARP Main Studs
-Stock Replacement Gaskets
-FMS 7.400" Pushrods
-FMS Ported LS6 Oil Pump
-Single Rollmaster Timing Chain
-GM Performance Stock Replacement Lifters
-Stock Rockers rebuilt by harland sharp w/ new bearings
-GM Head Bolts
-ARP "Cracked Rod" 2000 Series Rod Bolts
I've still need to order some bigger injectors. Any ideas on which ones and how much I'm looking at paying?
I'd also like to replace the tranny when I do the motor swap. Should I buy all the parts for the rebuild and have somebody do it? Pay to have it done by a local shop? Or get one from a sponser? As of right now nothing is wrong with it, but I know that as soon as I get the 383 in, it's gonna go out.
Any other comments or thoughts are welcome! Thanks!
all that for just 2k nice
TXsilverado
Nov 26, 2015 10:54 AM
USMCvet0311
Aug 1, 2015 07:45 AM
justuc
Jul 24, 2015 11:52 PM
grantpo
Jul 15, 2015 12:21 PM
