more results
Old Nov 26, 2005 | 08:29 AM
  #21
Kano's Avatar
Originally Posted by Dark Halo
what tranny are you running on your set up?
FLT level5
Old Nov 26, 2005 | 08:33 AM
  #22
Dark Halo's Avatar
4l60? of 4l80?
Old Nov 26, 2005 | 08:35 AM
  #23
Kano's Avatar
well I guess I could call it a 65
Old Nov 26, 2005 | 08:44 AM
  #24
Dark Halo's Avatar
once I get mine up it will be nice to compare how much of a difference it makes using a 65 vs an 80. We will be running close set ups. My cam and stall are a little larger and I am using 64cc patriot stage 2 ls6 heads in order to runn 11.1 compression. I just want to know how much this 80 is going to bring me down.
Old Nov 26, 2005 | 09:32 AM
  #25
parish8's Avatar
single digit dreamer
Originally Posted by JimS
Is the G-tech reasonablly accurate? With no track and no dyno available I"ve been thinkin I might do well with this $200 investment. Is it a decent bang for the buck? Thanks, Jim
it is very consistant and great for showing if you are geting improvements with your mods. it is also good for setting shift points. it absolutly kicks *** for working on your 60' time. you try diferenct launch rpms, diferent amounts of spin, diferent rates of rolling onto the gas and the gtech will tell you what works best. it is one of the best gadgets i have even paid for. you have to get the one that will let you download to your computer so you can compare runs and stuff.
i wouldn't use it to quote track times untill you goto the track at least once and use the gtech there and see what the "corection factor" is. for my truck it is .25sec almost exactly. the reason it is off i am told is due to body pitch after you get on the gas.
Old Nov 26, 2005 | 10:52 AM
  #26
Richard@WCCH's Avatar
FormerVendor
My experience with the G-tech unit was that it's incredibly accurate at least for my Camaro SS. I ran it at the track and it clocked within a hundredth of the tracks clocks. The mile an hour was higher by 2mph. I was told the higer mph is due to the fact that the G-tech measures at the end of the quarter mile as opposed to the track's clocks averaging the last 60 feet. Dunno, but it sounded plausible.......
Richard
Old Nov 26, 2005 | 04:46 PM
  #27
sittinlopro's Avatar
very nice truck. so you have a stock bottom end except for the arp rod bolts right? did you upgrade or change anything else not listed on the video like lifters, rockers, oil pump, timing chain and such or is it stock?
Old Nov 26, 2005 | 07:36 PM
  #28
Kano's Avatar
just the rod bolts
Old Nov 27, 2005 | 09:29 AM
  #29
Kano's Avatar
good deal we'll have to see how it turns out
I know I was impressed with 02denalis results when he swapped that 80 in
I was thinking it was gonna eat up more than it did
btw...youre gonna love that LQ9
kainzien
Nov 10, 2023 11:37 AM
Cha_Feel_
Sep 23, 2015 09:06 PM
FormulaZR
Sep 14, 2015 05:23 PM
fastjweb
Sep 1, 2015 11:21 AM
dselby25
Aug 24, 2015 07:26 PM
