AS&M header install help!!!!
Old May 25, 2003 | 11:07 PM
lm7's Avatar
lm7
Default AS&M header install help!!!!
I am doing the install right now but have come accross a bump in the road. I cannot get the passenger side manifold off because the dipstick is going right through one of the loops in the exhaust manifold. How have you guys gone around this?? Do I have to remove my dipstick??? I sure hope not...
Thanks!!
Robert
Old May 25, 2003 | 11:28 PM
CashDudeHomie's Avatar
Default Re: AS&M header install help!!!!
Just take the dip stick out. I think there is one bolt holding it in.
Old May 25, 2003 | 11:30 PM
Yeah, you have to take it off. There's no way around it. It just pulls right out after you take off one bolt. But it's a PITA to get it back in....especially in the dark with a 20 year old flashlight.
Old May 25, 2003 | 11:38 PM
LS1TECH Sponsor
The dipstick is a PITA if you don't have the truck on a lift or jack stands. I had a hard time getting the dipstick bolt in without keeping it from compressing the header flange, easily fixed with just a bench grinder.
lm7's Avatar
lm7
sorry I did not know that you could pull the dipstick out...I got it done now.
Old May 26, 2003 | 12:49 PM
lm7's Avatar
lm7
i got em on last night started it up its loud!!!! so looks like an open header memorial day, no one is open to weld it for me but as i took it for a test drive i ran into problem #1298437 on this install, now the steering hits the driver side header when i turn left!! sounds cool but this definitly wasnt like bolting up some hookers to a carburated small block.
Old May 26, 2003 | 10:19 PM
I heard you need to grind some clip on the steering shaft. You better do it before you scratch up the headers.
zblee
63
Jun 10, 2023 01:25 PM
Dan Neumann
11
Aug 7, 2022 09:06 AM
2500ZL1
Jan 25, 2016 06:30 AM
mrhino
Aug 7, 2015 10:01 AM
zblee
Aug 3, 2015 03:45 AM
