LY6 6.0 build what heads to use? HELP
Old Feb 16, 2012 | 06:29 PM
NVS05GMC's Avatar
Default LY6 6.0 build what heads to use? HELP
I have a 09 crew cab 4x4 sierra with a 5.3 that burns oil badly so I'm upgrading. My truck has the 6l80 and 342 gears. i just bought a ly6 out of a o8 van. The ly6 has the l92 style heads on it my truck came with the cathdrel style heads. So ill need a new intake. Here is my question i have a set of 243 off a 04 cts v would these be a better choice for a heaver crew cab with higher compression or keep the l92 heads? Anyone have a idea what the comp ratio would be on a 6.0 with 243's with stock head gaskets? please help!
plans are:
LY6 6.0
delete vvt
ls9 cam and ls9 valve springs(i can get the cam for $100 brand new)
211/230 562/558 lift 122.5 lsa
arp rod bolts/head bolts
1 3/4 arh long tubes catted Y
stock cat back
dyno tune
i tow a 7000lb boat so i need torque thats the goal. the 5.3 is a joke
Old Feb 16, 2012 | 09:19 PM
mitchellmade's Avatar
MASS seller approved
due to the eyebrows in a ly6 piston , i think you should stick l92 heads . i know the intake valves have differet centers but not sure if this can cause any interference .... unless you planned on building the bottom end
Old Feb 17, 2012 | 08:45 AM
NVS05GMC's Avatar
Anyone know this for sure if ill have clearance problems? if so how much should i mill the l92 heads to reach a 10.5:1 compression from 9.65:1 it has now?
Old Feb 17, 2012 | 08:49 AM
Robert91RS's Avatar
You won't have any clearance issues with the 243s and cam specs your looking at. Your 5.3 has flat top pistons and the same heads so why would a 6.0 have any less clearance?
Old Feb 17, 2012 | 02:03 PM
NVS05GMC's Avatar
Any idea what the comp ratio would be with the 243's?
Old Feb 17, 2012 | 04:24 PM
Robert91RS's Avatar
Hard to say without knowing how many cc's the valve reliefs are. Should be in the 10s though.
Old Feb 18, 2012 | 12:17 AM
Jablowme's Avatar
Banned
the 243's should be in the 10.5 11.0 with a flat top and reliefs
if you have the pistons with a slight dish alot lower
stay with the .051" gaskets
Old Feb 18, 2012 | 12:18 AM
10 Second Truck Club
keep stock l92s they flow really well
Old Feb 18, 2012 | 01:10 PM
NVS05GMC's Avatar
I decided to stick with the l92 heads all the info I found on people using the ls9 cam na had the l92 heads.
Old Feb 18, 2012 | 01:23 PM
NVS05GMC's Avatar
Anyone know how much I can mill the heads and still run 87 octane?
greedygenius
Sep 3, 2015 06:51 AM
USMCvet0311
Aug 14, 2015 10:28 PM
Jake75
Aug 5, 2015 01:26 PM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
