LY6 6.0 build what heads to use? HELP
I have a 09 crew cab 4x4 sierra with a 5.3 that burns oil badly so I'm upgrading. My truck has the 6l80 and 342 gears. i just bought a ly6 out of a o8 van. The ly6 has the l92 style heads on it my truck came with the cathdrel style heads. So ill need a new intake. Here is my question i have a set of 243 off a 04 cts v would these be a better choice for a heaver crew cab with higher compression or keep the l92 heads? Anyone have a idea what the comp ratio would be on a 6.0 with 243's with stock head gaskets? please help!
plans are:
LY6 6.0
delete vvt
ls9 cam and ls9 valve springs(i can get the cam for $100 brand new)
211/230 562/558 lift 122.5 lsa
arp rod bolts/head bolts
1 3/4 arh long tubes catted Y
stock cat back
dyno tune
i tow a 7000lb boat so i need torque thats the goal. the 5.3 is a joke
plans are:
LY6 6.0
delete vvt
stock cat back
dyno tune
due to the eyebrows in a ly6 piston , i think you should stick l92 heads . i know the intake valves have differet centers but not sure if this can cause any interference .... unless you planned on building the bottom end
