are the lt1 fans suppose to be noisy?
Old Dec 17, 2002 | 01:01 AM
really slow truck's Avatar
Default Re: are the lt1 fans suppose to be noisy?
yep, those fans are pretty loud. sounds like you need a louder exhaust though <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old Dec 17, 2002 | 01:04 AM
sleepersilverado's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> they are louder than the exaust. sounds like i have an industrial air conditioning unit in my engine lol </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">that is hilarious it hurt i was laughing so hard. thanks for the laugh <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
<small>[ December 17, 2002, 01:05 AM: Message edited by: sleeper silverado ]</small>
Old Dec 17, 2002 | 06:44 AM
ArticGMC's Avatar
I installed some ls1 fans on my sierra on Sunday. I had the + and - reversed on the fans so they were pushing instead of pulling. When I swapped them it quieted them down. The only time I can hear mine is if I walk around the front of the truck and just barely inside the cab stopped with no radio.
Lar
Old Dec 17, 2002 | 07:56 AM
BigTex's Avatar
Do you need them both on to keep the truck cool?
In the winter, 1 fan works fine for me. I have a toggle to turn it off when I want.
Old Dec 17, 2002 | 09:29 AM
ArticGMC's Avatar
Bigtex- right now the only time mine come on is around 175 and that is sitting in stop and go traffic right now in 70 degree weather. Other than that they don't come on. I have a 160 degree thermostat and it keeps the truck running around 170 running during the winter outside of stop and go traffic.
I have mine wired to both come on around 175. I've been trying to find a wireing diagram that will show me how to run the fans at half speed and full speed when the temp rises. I haven's had too much luck. I'm also considering just running one fan with temp switch and set the the other one to come on with a/c in the summer.
Lar
<small>[ December 17, 2002, 09:43 AM: Message edited by: ArticGMC ]</small>
Old Dec 18, 2002 | 09:06 AM
eallanboggs's Avatar
Do you remove you factory flex fan when you install the electric fans? I just bought a Flex-a-lite high output fan that's supposed to be able to cool a V8 by itself so I was planning to remove the stock fan. That's the whole reason for installing the electric fans anyway isn't it? Do you use the ECT sensor as your 12 VDC source and use a relay to handle the current. That's what I'd like to be able to do. Otherwise I'm planning on using a spare 20 AMP fuse I found in the Under Hood Fuse Panel that is for some option that my truck doesn't have. It's only HOT when the keyswitch is in the RUN position. The fan draws 11 AMPS continuous altho I'm sure it pulls a little more than that on startup. What terminal or fuse socket did you guys tap into?
Old Dec 18, 2002 | 09:59 AM
ArticGMC's Avatar
Yes you remove the stock clutch fan. Get a big enough wrench to fit the nut between the fan and the pulley and give it a couple of taps with a hammer. It will come loose just keep tapping counterclockwise. I used a fan wireing kit with an adujstable temp probe to turn the fans on when it gets to a certain temp from O'riley parts for $40. Works perfect.
Lar
bearden86
26
Nov 15, 2015 03:58 PM
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
trevorh1
Sep 27, 2015 08:47 PM
