Ls3 can and heads on 4.8
Old May 24, 2012 | 06:46 PM
  #61
mcfarlnd's Avatar
Un-Registered User
Originally Posted by 2011 4.8 killer
Does anyone know how much I can shave off the stock 799 heads to get higher compression
You can shave quite a bit. Depends on cam size (piston to valve clearance) and the target DCR, SCR, Octane level etc., etc. that you are trying to achieve with the cam you have selected.
Old May 24, 2012 | 10:28 PM
  #62
iamkeniff's Avatar
Originally Posted by mcfarlnd
The prc 2.5 5.3 heads do not come in a 243/799 casting..... They are two different castings with, two different programs written for them to be cnc'd. The core charge is also higher for the 243/799 heads which is the reason for the 300 dollar higher price tag. If the OP wants cnc'd 243/799s he can go with the stage 2.5 cnc'd LS6 heads. Two totally different set of heads.
Then i was told wrong.
Originally Posted by iamkeniff
Is is possible for me to send my 243 heads in for a cnc/port job like the PRC 2.5s or would it be best for me to just sell mine and buy a set of heads? The reason i ask is because i dont want to spend 1500 on heads when its not a "must", its a "want"
Thank you,
Niff
Yes we can do it!
$750 for CNC porting and valve job
$200 for larger 2.02"/1.57" valves (makes it stage 2)
$250 for PRC .650" spring kit
$1200 plus shipping get it all done!
Matt's pm back to me when i was looking into a set of heads for my 5.3 project.
Old May 24, 2012 | 10:30 PM
  #63
iamkeniff's Avatar
.035" safe and it still fit all your bolts in the powersteering bracket. .040"+ becomes an issue and you can't line up all the bolts on your bracket
Old May 24, 2012 | 10:55 PM
  #64
mcfarlnd's Avatar
Un-Registered User
Thank you,
Niff
Yes we can do it!
That program that they were going to run on your heads is for the heads I stated previously. The ports and chambers are totally different between the two. The program itself isn't interchangeable. I don't think you were told wrong, I think it is a mis-interpretation. When you say "like" the stage 2.5 5.3 heads doesn't mean you are getting the same porting as a 5.3 head. Notice the price difference when you said that you will send in your heads as well, 300 dollar price difference from the stage 2 ls6 heads. That's there price difference for the cores if you just buy them straight up.
Old May 25, 2012 | 08:53 AM
  #65
2011 4.8 killer's Avatar
Ok so what is dcr and acr. And I'm going to want to run that sleeper cam from TS and I only run 91oct. in the truck anyways. Also what springs should I get If I do my heads cuz I would like to upgrade them and will I need new pushrods as well.
Old May 25, 2012 | 08:54 AM
  #66
Sorry (scr)
Old May 25, 2012 | 09:11 AM
  #67
rjwz28's Avatar
Man Motor club
Dynamic compression ratio
Static compression ratio
OHsixLS3
Dec 27, 2016 09:30 AM
TXsilverado
Nov 26, 2015 10:54 AM
The_W
Oct 28, 2015 09:00 PM
The_W
Aug 15, 2015 08:07 AM
Denali08
Aug 9, 2015 04:34 PM
