Ls3 can and heads on 4.8
Old May 21, 2012 | 05:23 PM
  #41
2011 4.8 killer's Avatar
Hey I heard somewhere that the 4l80e with a mild shift kit is supposedly stinger than a fully built 4l60e is there any truth to that
Old May 21, 2012 | 05:39 PM
  #42
iamkeniff's Avatar
Yep. A stock 80e is better than most built 60e
Old May 21, 2012 | 08:52 PM
  #43
Thank you everyone!!!! y'all have helped me alot here
And I really do appreciate it
Old May 21, 2012 | 09:09 PM
  #44
BlackGMC's Avatar
Resident Retard
That 220/220 cam with the prc heads with a circled 3200 would be a nice combo.
Old May 22, 2012 | 10:19 AM
  #45
mcfarlnd's Avatar
Un-Registered User
Doesn't your truck come stock with 243s/799s??? Why don't you have them cncd and milled instead of messing with the 5.3 heads?
Old May 22, 2012 | 10:34 AM
  #46
iamkeniff's Avatar
The prc 2.5 5.3 heads come in a 243/799 casting. All you have to do is let them know. Plus it'd keep you from having to wait for the heads to come in. Or you ship them your heads, wait however long, pay 1000-1050 for them to do the 2.5 then install the heads. Save about 300-400.
Old May 22, 2012 | 01:00 PM
  #47
I'm not real sure what they have on them stock where's the casting number located so I can see what they are
Old May 22, 2012 | 01:09 PM
  #48
bigwillys58's Avatar
the casting number is easiest to see ob the passenger side. itll be a 3 digit cast-in number below the valve cover and all the way forward (front of the motor). so iamkeniff if i read your earlier post correctly, the stock lifters are good for 7k rpms? or is that only on the L20 and not the Ly2?
Old May 22, 2012 | 01:11 PM
  #49
Ok so same as the older trucks I'll check it out when I get to the house
Old May 22, 2012 | 01:12 PM
  #50
$ierraLY5's Avatar
If you are looking at the engine from the passenger side, the casting number should be on the very right hand end of the passenger side head ( I've never actually looked for the driver side), its pretty easy to find, shouldnt have to look real hard.
