Ls3 can and heads on 4.8
Old May 22, 2012 | 01:51 PM
  #51
iamkeniff's Avatar
Passenger head by the oil fill neck. Drivers head by the pvc port.
243/799 heads
When did i say the lifter was good to 7k
Old May 22, 2012 | 04:10 PM
  #52
2011 4.8 killer's Avatar
Ok I just got really confused on this but I just read something that said that the l20 has cathedral port heads so idk what the heck. I thought they were they square port and the ls3 was cathedral. I know I can't use the heads but maybe the intake manifold?
Old May 22, 2012 | 04:20 PM
  #53
$ierraLY5's Avatar
When you find the cast number let us know, I'm curious to know what the 4.8s have stock now.
Old May 22, 2012 | 04:29 PM
  #54
Ok so I just found this and now I can actually see the difference http://www.ls1gto.com/forums/showpos...22&postcount=7 so once again I cannot use the intake with the heads I have or the ones I want either. Ls3 are rectangle and 4.8 5.3 6.0 are cathedral as well as Ls2/6
Old May 22, 2012 | 04:31 PM
  #55
I also found this it's kinda informative on the l20.
http://www.gmpowertrain.com/Powertra...IV%20Story.doc
Old May 22, 2012 | 05:51 PM
  #56
bigwillys58's Avatar
sorry iamkeniff, i guess i misunderstood when you told OP "you already have good lifters." figgured that meant they would take some rpms...
Old May 22, 2012 | 08:43 PM
  #57
Ok so they are 799 cast heads but the cast numbers are not where you said they would be but exactly opposite spots. drivers side is on the front of the head under the alltinator bracket and passenger side is at the back by the fire wall
Old May 23, 2012 | 10:26 PM
  #58
Hemi2Slo's Avatar
12 Second Club
Correct me if I'm wrong guys, but won't stock 799 heads feed a 4.8 all the air it will ever want N/A?
Old May 24, 2012 | 06:19 PM
  #59
Does anyone know how much I can shave off the stock 799 heads to get higher compression
Old May 24, 2012 | 06:40 PM
  #60
mcfarlnd's Avatar
Un-Registered User
Originally Posted by iamkeniff
The prc 2.5 5.3 heads come in a 243/799 casting. All you have to do is let them know. Plus it'd keep you from having to wait for the heads to come in. Or you ship them your heads, wait however long, pay 1000-1050 for them to do the 2.5 then install the heads. Save about 300-400.
The prc 2.5 5.3 heads do not come in a 243/799 casting..... They are two different castings with, two different programs written for them to be cnc'd. The core charge is also higher for the 243/799 heads which is the reason for the 300 dollar higher price tag. If the OP wants cnc'd 243/799s he can go with the stage 2.5 cnc'd LS6 heads. Two totally different set of heads.
