LS1/LS6 intake on truck engine
Old Jan 23, 2006 | 09:44 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default LS1/LS6 intake on truck engine
Here's some pics of how we have done the last 2 5.3 street rod set ups. I think most of what we've done would work on the trucks also, but it's mainly just to give you some ideas if you are trying to figure out how to make the swap. I know we sell a lot of idler pulley relocation brackets; I don't know how many people actually complete the swap to the LSx intake.
Here's how we went from this:
to this:
On this one we kept the stock truck water pump, pulled out the hose nipple, made some band saw cuts in the bend so that it could be bent into a sharper turn, and then rewelded all of the cuts shut. We then drilled the new hole in the front boss (the one used on the F-bodies) and pressed the reformed truck nipple into the front. We finished it off by making an aluminum plug for the hole on top:
This gives decent clearance all the way around it and looks pretty good too:
We also switch to a car coilpack on the drivers side to clear the fuel fitting:
We've also done it with the car water pump and spacers, but I think this looks a little nicer.
Old Jan 23, 2006 | 10:00 PM
mattrem's Avatar
John, thank you for posting this. Its a huge help.
Old Jan 23, 2006 | 10:27 PM
Richard@WCCH's Avatar
FormerVendor
I very timely subject. The pictures are worth a thousand words. Thank you for shedding some light on this.
Richard
Old Jan 23, 2006 | 10:45 PM
Kano's Avatar
nice pics
but, I think if I tried that it would leak
what keeps it from leaking?
Old Jan 24, 2006 | 06:06 AM
tdrumm's Avatar
How much to modify a water pump like that?
Old Jan 24, 2006 | 07:17 AM
budhayes3's Avatar
PT's Slowest Truck
If and when this catches on, I wonder who's gonna be the first company to offer complete bolt on conversion kits that include tensioners, water pump, etc. They won't even need to do any R&D, just keep checkin this website!
Old Jan 24, 2006 | 03:51 PM
mattrem's Avatar
I think this is getting easier everytime someone does this.
Old Jan 24, 2006 | 05:06 PM
Speartech's Avatar
Originally Posted by Kano
nice pics
It won't leak. The parts were all precision machined.
Now if you were just gonna chuck it up in a vise and drill the hole, you might want to use some RTV or some kind of sealer!
Old Jan 24, 2006 | 05:10 PM
mattrem's Avatar
What did you use to cut the hole in the waterpump?
Old Jan 24, 2006 | 05:12 PM
Speartech's Avatar
I don't know. It's not a service I can offer. We are completely covered up in wiring harness orders. I have to stay focused on that.
