LS1/LS6 intake on truck engine
Old Mar 7, 2006 | 12:03 PM
  #21
It appears that the fuel rails are not attached to the manifold. It may have just been laid there to show how it was done.
Old Mar 10, 2006 | 03:31 PM
  #22
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Originally Posted by rubrhammer
John, in photos 1,2,4 &5 it appears that the belt as it passes from tensioner to idler is running a little further rearward than where it is on the water pump. Is this an optical illusion or is my eye sight really getting that bad? Nice looking job.
That IS an optical illusion! It's all lined up correctly, but it sure doesn't look like it in the picture.
Old Mar 12, 2006 | 07:36 PM
  #23
TURBO8's Avatar
does the water pump pipe just pull out? If so can I just push it back in after I modify it?
Old Apr 8, 2006 | 03:59 AM
  #24
TurboGibbs's Avatar
Bump for good info!
Old Jan 15, 2007 | 01:52 PM
  #25
s10mods's Avatar
Originally Posted by Speartech
Here's some pics of how we have done the last 2 5.3 street rod set ups. I think most of what we've done would work on the trucks also, but it's mainly just to give you some ideas if you are trying to figure out how to make the swap. I know we sell a lot of idler pulley relocation brackets; I don't know how many people actually complete the swap to the LSx intake.
Here's how we went from this:
to this:
On this one we kept the stock truck water pump, pulled out the hose nipple, made some band saw cuts in the bend so that it could be bent into a sharper turn, and then rewelded all of the cuts shut. We then drilled the new hole in the front boss (the one used on the F-bodies) and pressed the reformed truck nipple into the front. We finished it off by making an aluminum plug for the hole on top:
This gives decent clearance all the way around it and looks pretty good too:
We also switch to a car coilpack on the drivers side to clear the fuel fitting:
We've also done it with the car water pump and spacers, but I think this looks a little nicer.
anyone think the water pump from a l92 will work?
Look at the pics of how the upper hose exit's. Also would the l92 waterpump even fit on a 5.3 or a 6.0?
http://cgi.ebay.com/ebaymotors/2007-...spagenameZWDVW
Old Jan 15, 2007 | 02:02 PM
  #26
TurboGibbs's Avatar
very interesting. I bet it will work good. I don't know of any reasons that a gen4 water pump wouldn't fit?
Old Jan 15, 2007 | 02:05 PM
  #27
TurboGibbs's Avatar
Well it will definatly clear a cable tb but the dbw tb would be close.
Old Jan 15, 2007 | 02:13 PM
  #28
bluecajun5.3's Avatar
11 Second Truck Club
you can find cheap car waterpumps all day to do the swap. press the truck pully off the stock one and have it pressed on the car pump.
Old Jan 15, 2007 | 02:56 PM
  #29
onebadrubi's Avatar
bluecajun when are you going to do this swap? Are you drive by wire or cable?
Old Jan 15, 2007 | 03:00 PM
  #30
i'll be doing the swap this month or next.
i'm drive by wire.
parts are in sig
