LS1/LS6 intake on truck engine
Old Feb 21, 2007 | 07:58 AM
  #101
RST302's Avatar
So can an LS1 intake manifold be installed in a 06 4.8L truck.?
Old Feb 21, 2007 | 08:02 AM
  #102
v8
17,16,15,14,13,12,11 Drvr
yes, you will need to read all the write ups before proceeding, good luck.
Old May 1, 2007 | 12:11 AM
  #103
.T.'s Avatar
.T.
bump.
Old May 1, 2007 | 02:41 PM
  #104
LQ4_TRUCK's Avatar
Registered User
if i can ask a stupid question. why put a ls6 intake on there. wont the lq4 intake work since the flow on the #243 heads are the same as the #317 heads. i only ask because i dont know.
Old May 1, 2007 | 03:17 PM
  #105
silent1's Avatar
LS6 intake out flows all other STOCK manifolds allowing you to take more advantage of the #243 and #317 heads. Average gains are 10hp across the entire power band.
Old May 1, 2007 | 09:42 PM
  #106
v8
I plan to prove this wrong on the trucks in about 3 weeks when the truck returns to me.
Truck intake>LS6 intake
Old May 2, 2007 | 01:21 AM
  #107
silent1's Avatar
Just to correct my comment, average gain is 10hp over the ls1 intake and less over the truck intake, ~6hp.
v8, any reason in particular you don't believe it? Asking because the flow tests I've seen clearly show the LS6 manifold to flow best:
First flow test I've seen:
LS1 Intake
.200 .300 .350 .400 .450 .500 .550 .600
141- 185- 205- 222- 232- 241- 251- 258
Truck Intake
163- 206 -224 -237 -249 -262 -265 -270
LS6/00-02 Intake
166 -211 -229 -244 -257 -269 -277 -283
Second flow test I've seen:
LS1 Int.___70.2_142.6_189.1_203.2_216.5_226.9_235.3_23 8.1_238.1_237.4
LS6 Int.___70.2_144.4_200.0_215.8_227.6_238.1_244.9_25 0.2_256.0_263.0
Truck Int._70.3_143.9_194.4_209.8_220.5_229.2_234.2_237. 7_243.1_248.5
Old May 2, 2007 | 11:01 AM
  #108
.T.'s Avatar
.T.
So you're gonna prove that the LQ intake will outflow the LS6?
With the same TB?
No way.
Old May 2, 2007 | 07:59 PM
  #109
v8
The truck intake works so much better then the ls6 intake on the truck, now on the camaro no way
the ls6 intake may flow better on a dyno Queen, but in real life the truck intake is better for the truck.
you look at bluecajuns time and see gains, well he did go with bigger injectors,asp pulley, bigger converter, higher shift points all to gain .05 in the 1/4 and you think the intake is what did it?
if blue would go back to the truck intake with the same DA the truck intake would kick the ls6's a$$
Old May 2, 2007 | 09:35 PM
  #110
.T.'s Avatar
.T.
Only in the low end.
Say what you want about "Dyno-Queens" but nobody's lining up for SOTPmeters. If they are, I got a link to an Ebay auction that takes PayPal.
For all the guys running H/C (myself included) there's plenty of room to build power with a better flowing intake. The trick is to not oversize the cam and sacrifice the torque because bigger aint always better; especially when you're trying to launch 5,000lbs. This point gets F'd up waaaay too much.
If there was an easy conversion to the LS6 intake, I'd do it too and prove it's worth on the dyno and at the track while running my baby cam. But for now, look at my sheet from the day of my H/C swap and try to tell me that my motor wont benefit from getting more flow over 5k.
ps if Bluecajun (or anyone) omly picks up 5/100ths as you've stated after even just a TC, it's a tuning problem- not the intake.
