Low end power
#21
Originally Posted by Quik
you still have to regear even if not engaged. both diffs have to spin at the same time
How do you figure? Even though both diffs are spinning, if the transfer case isnt engaged theres no torque going to the front diff. He can run whatever gears he wants unless the transfer case engages.
#24
Originally Posted by 8ALTNG
Why are you so worried about low end power???? I only make 150rwhp at 3000rpms.. but no less than 400rwhp after 4000rpms
4.8's dont make good low end power.
4.8's dont make good low end power.Yep....put at least a 3000 converter, a short tire, and 4.10 gear. Then spin that lil 4.8 as high as it wants to go. Then when it wears out, build you a 6.0L. That's what I would do anyway.
#25
Back to the topic; I had a 224/224 cam in my stock 4.8 when i had a radix. It made 440ish and went 12.60, lifting a head
I think that your cam could work if you use it the right way.
#26
Originally Posted by moes04silverado
you know exactly what the cam does....terrible before 3500k after that though...wow....advancing the cam 4 degrees, how is that done??? and i have the long tubes...
Advancing the cam is done with an adjustable timing set.....usually under $150 for a good set.
You can try advancing the timing a little below 3500rpms and bring up your idle timing a little to help compensate for the lope....this will let the engine spin up a little faster.
I'd skip regearing for the cam.....just run a shorter set of tires and look for a 3500rpm converter. you'll limit your towing capacity but the truck will be a rocket !!
#27
ok i get the timing set, cant it be done with a degree wheel though?? im a little new at some of this so bear with me....
any brand of converter or is there one make better than others, or can i use one from a trailblazer??
But yelo your right about the rocket!!! at 3000 rpm that heavy *** truck takes off, of course my 8.1L would still smoke it!!!
#28
Fuddle http://www.fuddleracing.com/
zblee
63
Jun 10, 2023 01:25 PM
