Long tube/corsa delma
Old Oct 31, 2012 | 06:38 AM
Slammed silverado's Avatar
Default Long tube/corsa delma
Ok I have a 2000 rcsb 5.3 2wd silverado and was gunna do just a cat back corsa sport, but now I'm thinking of Texas speed long tubes, ory, Volant cold air, and a tune, but there a couple things I had questions about, would I get in trouble for not having cats cause for at least a couple more years it will be a daily driver, and I would do a tune and was wanting to kno when he does do the tune if he can make the front o2 sensors the primary o2's and would that keep the check engine light from coming on, any info would be great, thanks
Old Oct 31, 2012 | 11:50 AM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
where are you located? some states require emmission testing some dont, if you do live in a state that does it your truck will fail the test without the cats. If they dont test for it youll be fine. To get rid of the cel they simply have to turn off the rear o2 sensors and adjust for increased flow.
Old Oct 31, 2012 | 12:17 PM
Yes I live in st Louis Missouri and we do require emissions, but I will have it tuned, the guy that's doing it is well known around here for doing ls type motors and has done trucks so I can tell him just to increase the flow to the front two o2's? Ad what should I do with the remaining o2? Would would be the best thing to do with it?
Old Oct 31, 2012 | 10:49 PM
Sales3@Texas-Speed's Avatar
Truck Sponsor
The front 02s (upstream) dictate the afr reading for the pcm. The rear 02s (downstreams) are just in place for emissions, and tell the computer to throw an ses code if one is clogged or broken. With a tune the rears will be deleted out.
Old Oct 31, 2012 | 11:03 PM
GMCtrk's Avatar
They do a visual inspection there so you would fail unless you had dummy cats. The rear 02s can easily be tuned out.
Old Nov 1, 2012 | 10:31 AM
I have friends for visual lol and thank you to all that replied! All info helps a lot!! Can't wait to enjoy my Texas speed long tubes!
Old Nov 1, 2012 | 04:35 PM
texasglock23's Avatar
If you have friends for inspections, what are you worried about? No other way for you to get in trouble unless stopped and they inspect.
Run LT's, enjoy them. But running cats won't cost you any performance that you will see. Dummy cats are helpful to some. As mentioned, a tune will correct your CEL.
Old Nov 1, 2012 | 05:59 PM
I'm just worried about the computer part but that's it, I have been talking with a lot of people, also talking with guys on here I have had my mind eased about this but I'm excided about putting them on and seeing the gains! Truck ran a 15.86 stock in 1/4 so I'm hoping for high 13's
twake_410
Apr 14, 2016 09:58 PM
bearden86
25
Nov 1, 2015 07:12 PM
91LT16SpeedFormula
Oct 1, 2015 08:57 AM
jscherbs
Sep 30, 2015 07:54 AM
old motorhead
Sep 29, 2015 08:22 PM
