lifted 4x4 headers
lifted 4x4 headers
I got an 01 1500 5.3 that's got a 6" lift. I've heard people running into problems with the y-pipe interfering with the front drive line. Is this true ?
11 Second Hall Moniter
The left side of the y-pipe has to go under and around the front driveline. If your lift kit (many do) relocated your front differential lower in the chassis, then you will have to modify the left side of the y-pipe. Usually involves a little cutting & welding to make it work, exhaust shops do it all the time, even on the stock y-pipe.
Had to do it with mine on a rcx 6". The bend on the y-pipe that goes under the driveshaft needed to be bent down a lil and welded. Clears it plenty now after the shop got a hold of it
zblee
63
06-10-2023 01:25 PM
ARC
57
02-21-2022 10:54 AM
