lifted 4x4 headers
I got an 01 1500 5.3 that's got a 6" lift. I've heard people running into problems with the y-pipe interfering with the front drive line. Is this true ?
The left side of the y-pipe has to go under and around the front driveline. If your lift kit (many do) relocated your front differential lower in the chassis, then you will have to modify the left side of the y-pipe. Usually involves a little cutting & welding to make it work, exhaust shops do it all the time, even on the stock y-pipe.
Had to do it with mine on a rcx 6". The bend on the y-pipe that goes under the driveshaft needed to be bent down a lil and welded. Clears it plenty now after the shop got a hold of it
on my 2004 Z71 that has an RC 6" Non-Torsion Drop Suspension. Mine bolted right up no problems at all. I even have the 2 inch keys and had the rear springs re arched.
Ok, good info thanks!
Also will f-body headers work on our trucks? Reason i ask is cuz a buddy of mine is giving me his long tubes of his camaro |
Originally Posted by wckdZ71
(Post 4960733)
F-body headers WILL NOT FIT on a 4x4 truck. Just so you know....
ok, thanks for the heads up. Whats the issue on a 4x4 with f-body headers?
The front driveline is the issue.
