What flow rate are my injectors?
Old Mar 30, 2012 | 09:47 PM
NLalexx's Avatar
Default What flow rate are my injectors?
THE NUMBER IS 12594512
I also wanted to know if my Truck connectors will connect directly or i would need adapters for it? its a 2000 GMC sierra 5.3
THIS IS THE INTAKE
Old Mar 30, 2012 | 09:53 PM
NLalexx's Avatar
Forgot to say its a NNBS intake.. 2008 from an avalanche... i bought it off EBAY... and wanting to swap it out.. but dont know what do i need.. Fuel regulator... and im going to put a adapter plate for my 78mm ported since i dont have 350 to spend on a 90mm Yet down the road.. what else would i need connectors? or will mi stock ones fit does injectors?
Old Mar 30, 2012 | 09:54 PM
2000chevysilverado's Avatar
Your doin the same thing I am you can put your stock injectors in so I've been told
Old Mar 30, 2012 | 09:55 PM
14psisupra's Avatar
36lb flex fuel
Old Mar 30, 2012 | 09:56 PM
NLalexx's Avatar
but ive heard that if you put your stock ones you will need some kind of spacers or something.. and also if i find out they are more LB flow than my stockers i think it would be better to put the ones this intake has... hope they are flex fuel but dont know the exact flow #s
Old Mar 30, 2012 | 09:57 PM
NLalexx's Avatar
Originally Posted by 14psisupra
36lb flex fuel
thanks bro! do you know if i need connectors adapters ect.. or will it plug right in?
Old Mar 30, 2012 | 09:58 PM
I've been researching to the look like the will connect but I'm using a spare intake off a 03 and robbing parts off the 03 intake its weird has a dbw 3 bolt throttle body
Old Mar 30, 2012 | 10:01 PM
NLalexx's Avatar
So you want it electric with a x link? or you keepin it Cable driven?
Old Mar 30, 2012 | 10:02 PM
I'm keeping cable drivn like it better less to go wrong
Old Mar 30, 2012 | 10:08 PM
NLalexx's Avatar
mee too but they are little expensive around 300+ dollars while the intake with injectors and fuel rails was 90 buks lol... i need a corvette regulator i guess thats like 50 more and a throttle body adapter which is like 30-40 buks from fast ... + the installation or is it not hard at all?
