Lets play...Name that broken part
Old Oct 30, 2005 | 12:55 AM
  #221
moregrip's Avatar
what a rush!
Originally Posted by 1SlowHoe
Does anybody (Sponsor) do a regular bore 6L with forged internals? What is a reg 6L 363ci?
http://www.wheeltowheelinc.com/pc-67...ort-block.aspx
Old Oct 30, 2005 | 01:00 AM
  #222
1SlowHoe's Avatar
Destroyer of Transmissions
It's pretty but, it's about $700 more than the other two I've priced. And they were 402's.
Old Oct 30, 2005 | 01:01 AM
  #223
How much are you planning to spend?The 402/408 shortblock specials don't include a cam or heads.A Radix 403 with a 2.75" pulley will only make 7lbs of boost,so if you want to make big hp numbers with that setup you'll need a big cam and heads setup to make power at a higher rev range.That drives up the costs pretty quick.I'm currently looking at the new intercooled Whipple setup that uses a AX3300 supercharger for my 403,I'm thinking that set up will be worth about 750rwhp with a milder cam and on pump gas.
Old Oct 30, 2005 | 01:05 AM
  #224
moregrip's Avatar
what a rush!
lol, sounds like those 402's are pretty reasonable then, so you've been quoted about $3300 for a 402?
Old Oct 30, 2005 | 01:06 AM
  #225
1SlowHoe's Avatar
I've got a cam and springs and I was going to use stock 6L heads on whatever I get. I am willing to go 3000-3500 for a new, forged short block. So far the 402's are cheaper than a regular bore forged 6L. If I can find a used LQ4/9 I will just use it and not do any more than 8#'s and a 50 shot. I decided against the 402 because of your problems feeding it with a Radix.
Old Oct 30, 2005 | 01:07 AM
  #226
1SlowHoe's Avatar
Yes sir,
https://www.performancetrucks.net/fo...d.php?t=350908
https://www.performancetrucks.net/fo...d.php?t=350863
Old Oct 30, 2005 | 01:08 AM
  #227
moregrip's Avatar
what a rush!
don't you need a long block? or will you use your 5.3 heads?
Old Oct 30, 2005 | 01:12 AM
  #228
1SlowHoe's Avatar
I was gonna find some stock 6L heads on ebay or on here. I don't want to use the heads off the 5.3. I will of course use every other part
These seem a little overpriced but more will come available....
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Oct 30, 2005 | 01:18 AM
  #229
moregrip's Avatar
what a rush!
how about this? everything is there for ya:
http://www.sdpc2000.com/catalog/123/...-C-K-G-LQ4.htm
Old Oct 30, 2005 | 01:24 AM
  #230
1SlowHoe's Avatar
Do they mean EVERYTHING from the intake to the oil pan? I would have a lot of left over parts from the 5.3 huh?
