If you have AFM keep up with your oil changes and viscosity
Old 07-26-2008, 09:25 AM
eallanboggs's Avatar
Default If you have AFM keep up with your oil changes and viscosity
Just finished a course on GM Powertrain Perfomance 2003 to 2008. The instructor mentioned how important it is for AFM engines to have clean oil and also have the correct viscosity. This is important for any engine, but even more so for AFM because of the small passages the oil must pass through(in the AFM lifters and their associated solenoids). Not only must the oil be free of debris, but it must be a light viscosity to flow properly. The AFM system is so fast GM says it is transparent to the driver. That means the lifters have to pump up and bled down so fast you can't feel it as it switches back and forth between AFM mode and normal mode. If you have AFM keep your oil changed and use the right viscosity(it's posted on the filler cap).
Old 07-26-2008, 08:03 PM
yammahoppy's Avatar
I just bought an 08 with the AFM. After a break in period (say after 2nd oil change or whenever recommended) will switching to a pure synthetic effect the engine? I used Royal Purple in my 04 and really liked it.
Old 07-27-2008, 02:45 AM
LS1Tech Whore
Dirty 30's Avatar
I'd stick to Mobil 1 synthetic. Royal Purple is for the mustangs and ricers :p
Old 07-27-2008, 09:16 AM
03sierraslt's Avatar
No kidding, I guess that means I have a ricer
Old 07-27-2008, 09:22 AM
LS1Tech Whore
Dirty 30's Avatar
i was jk dont take me serious
Old 07-27-2008, 10:00 AM
PT's Slowest Truck
budhayes3's Avatar
You'll be fine with switching to synthetic, just use the recommended viscosity.
Old 07-27-2008, 08:20 PM
Actually now that I think about it, I dont have RP in it anymore.. I got amsoil in it. ( I run it in my bike and the price was good so I got some for the truck too.)
Old 07-27-2008, 11:56 PM
LS1Tech Whore
Dirty 30's Avatar
Amsoil is ricer too :p jk
Old 07-28-2008, 07:17 AM
yammahoppy's Avatar
See, now I am confused, I thought all ricers did was put the go fast stickers on their cars an not do anything that actually helps the engine.........
Old 07-28-2008, 10:33 AM
LS1Tech Whore
Dirty 30's Avatar
ricers dont touch the engine other than adding flourescent wireloom and an intake.
lukn4trbl355
10-21-2015 11:19 PM
sTNT971
09-26-2015 04:22 PM
lxcoupe
09-25-2015 12:36 PM
69z-28
09-21-2015 07:31 AM
Velocity1
09-15-2015 11:29 PM
Quick Reply: If you have AFM keep up with your oil changes and viscosity
