If this doesn't fix it I give up
Old Oct 3, 2009 | 07:54 PM
  #31
jhe2003's Avatar
Well ****! lets try the higher octance first, if still present then gotta look at common things that will cause a "knock" (I'm sure you already have) carbon deposits, loose mounts, loose tc bolts, exhaust hitting on frame at WOT bc of loose mounts, electrical wiring, BAD PCM(may be not) after that...... teardown I guess!
Let us know what you find
Old Oct 3, 2009 | 08:04 PM
  #32
GMCtrk's Avatar
nothing is making any noises. I HEAR NO KNOCK! How much timing do you think a 10.6:1 motor can take on 93 octane?
Old Oct 3, 2009 | 08:08 PM
  #33
dlt76028's Avatar
Originally Posted by gmctrk
nothing is making any noises. I hear no knock! How much timing do you think a 10.6:1 motor can take on 93 octane?
24-25
Old Oct 3, 2009 | 08:18 PM
  #34
GMCtrk's Avatar
my highest timing is 24 degrees. I actually lowered the timing from the stock lq4 high timing table
Old Oct 3, 2009 | 08:20 PM
  #35
Daryn's Avatar
Formerly darynC-10/23/10
block the holes off and turn the stupid knock sensors off
Old Oct 3, 2009 | 08:21 PM
  #36
GMCtrk's Avatar
are yours off?
Old Oct 3, 2009 | 08:24 PM
  #37
dlt76028's Avatar
have they been desensitized at all? and yea you can just turn them off.
Old Oct 3, 2009 | 08:27 PM
  #38
GMCtrk's Avatar
I'm also noticing if I have my log file open and it says like 23 degrees of timing whereas the corresponding cell lit up in my tune says 20 degrees. WTF
Old Oct 3, 2009 | 08:28 PM
  #39
GMCtrk's Avatar
it's the stock 02 LQ4 knock sensor settings
  #40
jhe2003's Avatar
Is it safe?
