If this doesn't fix it I give up
#132
You can barely fit the gauge up through the cowl, and keep the hood latched in the popped position (I put a zip tie on it just to be safe).
Why don't you try loading in a bone stock LQ9 tune, just for ***** and giggles. It probably won't even be close, but it'd be worth a shot.
I couldn't load an LQ9 tune and had to use LQ4 instead because there was never an LQ9 used with a cable TB.
#133
And why can't you take an LQ4 tune and copy in all the LQ9 data? That's if its really all that different. My point is just trying a different tune, something completely stock.
#136
I just read the thread, and my head hurts... The MAF I sent you was in good shape as of when I took it off and went to a SD tune. I descreened it before I knew any better LOL... bottom line, get a wideband, get a catchcan, I got my nice aluminum Moroso can for about $80 from Summit. Get a cam that goes with the heads you have, and get a tune... not a guess.... if you cant tune it. I'm sure Justin could make you up a good baseline to start with.
#140
