If this doesn't fix it I give up
Old Oct 5, 2009 | 09:12 PM
  #121
GMCtrk's Avatar
I have a descreened MAF. According to Justin that lowers readings by 10%
Old Oct 5, 2009 | 09:13 PM
  #122
GMCtrk's Avatar
your the one with problems not me..
Just messin with ya. I know you guys are right. Not much $$$ at this point to go buy this stuff at will. Once I saw that oil in my heads I knew I needed a catchcan.
Old Oct 5, 2009 | 09:16 PM
  #123
BlackGMC's Avatar
Resident Retard
ya that is true, or so i have heard... Add a new MAF to your list too...
I am not trying to be a dick or anything.... It is jsut kinda painful reading your threads over and over again... And once again 880mv is not 12.0 AFR or anywhere close it is more like 13.0....
Old Oct 5, 2009 | 09:19 PM
  #124
GMCtrk's Avatar
It's barely a modded motor, that's why I figured it should run just fine on the stock tune. People on tech noted that when they added heads it ran just fine on the prior tune, albeit the AFR did go up a tad.
Old Oct 5, 2009 | 09:21 PM
  #125
BlackGMC's Avatar
Resident Retard
Allrightly i am done trying to help... Enjoy...
Old Oct 5, 2009 | 09:24 PM
  #126
GMCtrk's Avatar
Appreciate your help
Old Oct 5, 2009 | 09:30 PM
  #127
budhayes3's Avatar
PT's Slowest Truck
The wideband is definitely a good idea, I'd listen to Corey on this one. Get the catch can too, just to keep the oil out of your intake and combution chambers...as I've mentioned to you I think they should come with one from the factory lol. But the first thing I'd do, if the O2 readings are going lean, is get a mechanical fuel pressure gauge, the universal ones that screw into the fitting on the fuel rail are pretty cheap...check out thetoolwarehouse dot net, I buy a lot of tools from there at great prices. Good luck Michael, I'm sure that when you figure it out you'll probably say "why didn't I think of that first?!"
Oh yea, I hate descreened MAF's, everything I've heard has been negative, and I've heard that they can make tuning a bitch...can you go speed density for the time being? (I'm a noob with tuning, so if that's a stupid question, forgive me)
Old Oct 5, 2009 | 09:32 PM
  #128
GMCtrk's Avatar
How am I going to see the gauge while driving hmmm... some people tape the gauge to the winshield?
Old Oct 5, 2009 | 09:35 PM
  #129
BlackGMC's Avatar
Resident Retard
actually now that is a damn good idea....
Old Oct 5, 2009 | 09:37 PM
  #130
00ChevyScott's Avatar
Wearin' da big hat
You can barely fit the gauge up through the cowl, and keep the hood latched in the popped position (I put a zip tie on it just to be safe).
Why don't you try loading in a bone stock LQ9 tune, just for ***** and giggles. It probably won't even be close, but it'd be worth a shot.
