If this doesn't fix it I give up
Old Oct 5, 2009 | 08:49 PM
  #111
BlackGMC's Avatar
Resident Retard
Originally Posted by GMCtrk
Because this isn't a LQ4 engine. It's a LQ9 with ported heads and higher compression running on a modified LQ4 tune. It's possible that the fueling is off, but I find this highly unlikely because I've had KR on those logs when the o2s are reading above .900mV
comanding 12.0 is a hell of alot richer than 880mv.... it should be in the 950s or higher....
Old Oct 5, 2009 | 08:55 PM
  #112
GMCtrk's Avatar
I'm not sure what to say to that. Other fueling tables may be off. I don't think you can really go off the commanded AFR table as gospel
Old Oct 5, 2009 | 08:58 PM
  #113
GMCtrk's Avatar
So things to consider:
1)Wideband
2)fuel pressure gauge
Old Oct 5, 2009 | 09:01 PM
  #114
nonnieselman's Avatar
would you atleast listen to corey, or just quit..
You dont know your fuel pressure, AFR, or anything. So your chasing a dead end trail without actually knowing whats goin on..
Atleast get a wideband.
Old Oct 5, 2009 | 09:02 PM
  #115
Things to get:
Wideband
Old Oct 5, 2009 | 09:03 PM
  #116
GMCtrk's Avatar
you homo
Old Oct 5, 2009 | 09:07 PM
  #117
im just saying...
corey told you stuff to try... go try it and he can help you more,, or go get a freakin wideband.
Old Oct 5, 2009 | 09:08 PM
  #118
GMCtrk's Avatar
Old Oct 5, 2009 | 09:09 PM
  #119
BlackGMC's Avatar
Resident Retard
If you tune is correct, commanded = Actual.... NOW that is Gospel...
Also looking over you tune and comparing it to stock the MAF table has been increased by 5% in the 0-5000hz and 15% from 5000-12000hz...
Looking at my current tune compared to stock the largest difference in the entire table is about 3-5% and mine is calibrated with a wideband (i was kinda shocked when i saw that, strange huh)....
BTW you can forget increasing your MAF to try and compensate... IMO you have delivery issues... Another clue is your running stock injectors with only a 93% IDC....
Old Oct 5, 2009 | 09:11 PM
  #120
your the one with problems not me..
