If this doesn't fix it I give up
Old Oct 6, 2009 | 05:19 PM
  #141
built408's Avatar
Just turn them off. Putting way too much time and effort into this.
Old Oct 6, 2009 | 05:21 PM
  #142
nonnieselman's Avatar
Originally Posted by GmOnEy Z71
you can make it without them... just pay attention to your truck and i always buy gas at good gas stations and if you notice it messing up dont drive like a *******... cars didnt even have knock sensors till what 96
yea i know, i desensitized mine from my springs,pushrods.. but only in the lower RPMs.. it doesnt throw any KR up high.
Old Oct 6, 2009 | 05:39 PM
  #143
GMCtrk's Avatar
I'll keep the sensors and rectify the problem before I turn them off. As several have stated, they are a good thing to have.
Old Oct 6, 2009 | 05:47 PM
  #144
silver-mod-o's Avatar
Hunt&Fisherator
you still probably need to turn them down like was stated before. but I doubt youve done that anyway... or will want to.
Old Oct 6, 2009 | 05:55 PM
  #145
GMCtrk's Avatar
Actually you're incorrect.
Old Oct 6, 2009 | 05:56 PM
  #146
GMCtrk's Avatar
not to sound like an *** (lol) but I've already assessed that. They still may need to be desensitized further, but I'll leave that as a last resort.
Old Oct 6, 2009 | 05:57 PM
  #147
joeyc125's Avatar
11 Second Truck Club
I had the oil in the intake problem as well. My conclusion is there is too much suction in the valve cover, sucking oil into the system. I would use 1 qt of oil every 500 miles. I cut the pcv hose to the intake, put a fuel fitting in there which necked the hose diameter down to about 3/16". The system still works as it should, but i have absolutely 0 oil consumption now, and when i pulled the intake last time it was definitely much much cleaner. I think it had so much vacuum in the valve cover it would just suck any oil droplets being thrown around right into the pcv system. I was going to use a catch can, but i believe this fixes the problem vs band aiding it. FI motors are different though, they actually have a considerable amount of blowby whereas we shouldn't have as much.
Old Oct 6, 2009 | 06:01 PM
  #148
GMCtrk's Avatar
I plan on boosting, so the catch can should be a decent investment. Only peeves me that I wont get the can until nextweek so the top end I'm sure is already coated with oil already.
Old Oct 6, 2009 | 10:27 PM
  #149
budhayes3's Avatar
PT's Slowest Truck
GM's been using knock sensors since at least the early 80's...they actually used to put them in the water jackets, I got a shower when I removed mine on my 85 MonteSS. We used to try tricks like putting teflon tape and RTV on the threads of the sensor to try and de-sensitize them. They used to be real sensitive to how tight they were tightened too...if they were over-torqued the car would run like a dog because the knock sensor would become over sensitive and the "ECM" (that's what they were called at the time), would pull timing.
Old Oct 7, 2009 | 03:19 PM
  #150
Hunt&Fisherator
of course....................
