I think I might have a problem!
Old Dec 31, 2005 | 08:07 AM
mattrem's Avatar
Default I think I might have a problem!
Well just finished up the cam swap, started the truck up everything was good and now it has a crazy valvetrain noise. I put the cam in turned the motor over by hand several times, I quess if the Piston to Valve clearance was going to be a problem I would have seen it then, Correct? Well It sounds like a sewing machine, just it has never sounded like this. Anyone have any ideas? Did the lifters pump up causing a P to V problem?
Old Dec 31, 2005 | 08:13 AM
joshluther's Avatar
What length and brand pushrods are you running?
Old Dec 31, 2005 | 09:10 AM
mattrem's Avatar
Well I quess I had a lifter that needed some oil, Everything is all good now. I went back out started it up and it got quiet. It scared the hell out of me! I know that this combonation is close with the P to V clearance, so this is why I thought that.
I took it for a ride and it feels alot stronger than the other cam, the power is very smooth. It seems to come off idle better than the other cam also. It idles with a very faint lope, almost like a sleeper. I am very pleased so far
Old Dec 31, 2005 | 09:14 AM
Richard@WCCH's Avatar
FormerVendor
How is your oil pressure? Sounds like the oil pump pickup "O" ring got cut during the cam install. This happens very often to even the best installers. Was the lifter preload about the same as the old cam?
I'll be in the shop till 2 this afternoon. Call me and we can go down the list of possibilities.
Richard
Old Dec 31, 2005 | 09:28 AM
mattrem's Avatar
Everything is good Richard. It must have been a lifter that needed oil. I went out and figured if the pistons are hitting the valves it would blow up when I gave it some gas so, I went for it and it got quiet! Just scared the crap out of me thats all.
I know one thing, its a whole new beast.
Old Dec 31, 2005 | 10:54 AM
Sport Side's Avatar
-When are you going to the track?
-Do you know the full specs to the cam? Interested.
Thanks
Old Dec 31, 2005 | 10:59 AM
moregrip's Avatar
what a rush!
glad to hear all is well and you are happy
Old Dec 31, 2005 | 11:29 AM
mattrem's Avatar
Thanks
Not going to the track until next month, Etown opens in Feb. I hope to get to the dyno next week or two.
The cam is a Comp 220/224 581/581 on a 115LSA
Old Dec 31, 2005 | 11:31 AM
mattrem's Avatar
Everything is good, just thought that I had a big problem. Never have heard such a noise, I mean it was crazy.
I know the truck feels a whole lot better
Old Dec 31, 2005 | 11:37 AM
moregrip's Avatar
what a rush!
I think your engine likes those XER lobes
