I think I might have a problem!
Old Dec 31, 2005 | 03:18 PM
  #21
hirdlej's Avatar
Originally Posted by mattrem
Everything is good Richard. It must have been a lifter that needed oil. I went out and figured if the pistons are hitting the valves it would blow up when I gave it some gas so, I went for it and it got quiet! Just scared the crap out of me thats all.
I know one thing, its a whole new beast.
Matt,
When I did my cam swap my truck did the same thing. It's normal whenever doing a cam swap on a motor with hyd lifters. When you go through setting up the lifters and torquing the rocker studs down, you squish all the oil out of the lifters and they lose their prime. I had a 2 lifters that wouldn't pump up even after idling for 5 minutes. I had to go for about a 10 minute drive around town raising and lowering the RPM's got the oil warm and the pressure to fluctuate and pump the 2 bum lifters back up. All is well now as well
Old Dec 31, 2005 | 03:28 PM
  #22
mattrem's Avatar
Originally Posted by hirdlej
Matt,
In all the times the rockers have been off this truck I have never heard this kind of noise. One side started then the other and then I shut it off. Then I said if its going to blow up then I can build a 408 and stepped on the gas.
Old Dec 31, 2005 | 04:51 PM
  #23
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Thats the attitude to have
Im the same way about my 418 now if it just makes it back to texas then blows Ill be happy then I can make me a 434 or 438
Old Dec 31, 2005 | 05:01 PM
  #24
mattrem's Avatar
I knew you where going to like that comment
Old Dec 31, 2005 | 05:07 PM
  #25
1slow01Z71's Avatar
Hell after you work on stuff for a while you get to the point where when something breaks its not an "oh ****" occurence its a chance to upgrade
Makes things a hell of alot easier to deal with atleast for me since I have a knack for blowing stuff up/ breaking things.
Old Dec 31, 2005 | 10:25 PM
  #26
mattrem's Avatar
I hear you, I think this is the best this truck has been. Only thing that will make it better is a Radix. Then if it blows up, well I don't know.
Old Jan 1, 2006 | 06:07 AM
  #27
1slow01Z71's Avatar
You need to get a stall in that turd
It will make such a huge difference, one of the best mods I did out of everything.
Old Jan 1, 2006 | 07:09 AM
  #28
mattrem's Avatar
Yes I need a stall, that will be in the spring I think. I Need to think about a built trans or getting someone to build this one.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
