how to reach 14's
Old Dec 1, 2006 | 06:54 PM
  #31
Shea's Avatar
Along with what Jake has said, I agrre with most of what he says here too. Save yourself a transmission and try to hook up with tires and 2WD without using 4WD. If you plan on doing transmission work, then preparing it for that kind of driving would be necessary if you want it to hold.
As for installing, there was a guy who was installing the stall on his TBSS and punctured some things and ended up costing him ALOT of money. Not trying to scare you, but I really wouldn't recommend doing it unless you are familiar with transmissions. Also, on top of the $300 cost of the stall, remember to factor in the cost of the cooler and then any installation you may need. I think a cooler will run you about $150.
Old Dec 1, 2006 | 06:57 PM
  #32
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Originally Posted by Shea
then you need a trans brake because often times the brakes aren't strong enough to hold it.
True... have that problem now.
Originally Posted by jakebdb56
launching in 4wd is alright. but unless you're traction impaired I dunno if I'd really do it, just to save my t-case.
PM 'white1' about that. He launches in 4wd pretty often. I've heard him say it's REAL interesting during sideways burnouts in forward motion! May have to try that one day.
Old Dec 1, 2006 | 07:30 PM
  #33
Quik's Avatar
5 year bitches!
look at parish he launches in 4wd
Old Dec 2, 2006 | 07:20 AM
  #34
dropkick13's Avatar
parish's truck is a tiny bit more modded than mine haha
thanks for the info on the stall. whats a good rpm range to look for since this is my daily driver....im really only looking to get this thing into mid/high 14's but since its an ext cab stnd bed 4x4, it will take some work
Old Dec 2, 2006 | 07:38 AM
  #35
Shea's Avatar
Since your stock stall is at about 1400 RPMs, IMO, you would be happy with a 2800 stall. Anything less and you may think it's not enough, much more and you may feel it's too much.
Like I said above, some of the bigger enthusiasts may go for a 3200-3600 stall, but unless you are serious about having a fast truck, then stay with the 2800
Old Dec 2, 2006 | 09:29 AM
  #36
dropkick13's Avatar
and what will a 2800 stall do to my gas mileage? what brands should i look at?
Old Dec 2, 2006 | 10:38 AM
  #37
Shea's Avatar
Shouldn't be too much of a difference. In order to stall it, you still need to hold the brakes, so with normal driving, you won't notice much, if any, revving before pulling out.
Old Dec 2, 2006 | 01:47 PM
  #38
hard2kill's Avatar
i was told to go with a yank 3000tt converter nice guy told me alot about it and said i could still tow and do my daily drivin 800 or so miles a week i have pretty much the same truck as you 04 ext cab sb 4wd 5.3 let me know what you end up going with
Old Dec 2, 2006 | 03:03 PM
  #39
dropkick13's Avatar
i just bought this truck...so the mods are just beginning. first is a muffler swap, intake, tune. then im trying to decide between headers, stall, or gears next. after one of those ill be having to save up money again for a while
hard2kill...what other mods do you have? any 1/4 passes or dyno #'s? whats your gas mileage?
Old Dec 2, 2006 | 05:49 PM
  #40
Dock Rocker's Avatar
nonnieselman Got a 14.9 qtr with 140,000 miles on the clock and an exta cab. All he had a the time was EFI Live and he was tuning it himself. PM him and ask what he did. I thin he had some magnaflows as well.
