HOW INT THA f$%k DOES THE TRANS DIP GO BACK IN?????
Old May 3, 2008 | 12:27 PM
Mangled03gmc's Avatar
Baltimore Whore
Default HOW INT THA f$%k DOES THE TRANS DIP GO BACK IN?????
Everything is in ready to go, I usually have a good deal of patience but after about an hour or so I can't for the life of get the god damn trans dip back in, am about ready to drive this truck off the pier into the drink.. Any tips info or tricks?????????????
Thanks John
Old May 3, 2008 | 12:48 PM
CashDudeHomie's Avatar
I had the same problem. I also managed to get the bracket part of it bolted between the engine and tranny, so I had to loosen the bolts again Just keep fighting with it dude.
Old May 3, 2008 | 12:51 PM
KySilverado's Avatar
Yep.... a PITA. Patience grasshopper. Up, down, twist, cuss, rinse and repeat. No real trick that I have found anyway.
Old May 3, 2008 | 04:05 PM
quicksilverado's Avatar
If you can get someone to push from the top while you are underneath the truck to guide it into place it is easy.
Old May 3, 2008 | 04:31 PM
dirt track racer 81's Avatar
heres my tip..next time you go to put the trans in, put the dipstick in before you bolt it up..
Old May 3, 2008 | 04:51 PM
SpoolinChevy's Avatar
It went in first try for me when i fed it from the bottom.
Old May 3, 2008 | 04:57 PM
charcold-bowtie's Avatar
yup, i left mine i place.
Old May 3, 2008 | 05:32 PM
Baltimore Whore
Ok guys thanks we got it in, the bastard didn't want to clear the back of the head..
John
chopperloco
Jul 10, 2016 10:45 PM
thunder550
Oct 8, 2015 04:53 PM
Ls3silverado
Jul 31, 2015 04:22 PM
walledition
Jul 29, 2015 08:54 PM
KyleW707
Jul 29, 2015 08:17 AM
