How does the 8100 like e-fans?
Old Aug 15, 2006 | 01:27 PM
tb8100's Avatar
Default How does the 8100 like e-fans?
I've been lusting after the Flex-a-lite dmax efan that blows some 6000 CFM. the dimensions are exactly the same as the 8100, so it should bolt right up. i'm not planning on racing the truck (very much), and it runs with a 2-3K trailer behind it about 50% of the time, sometimes as much as 8-10K, though that's not very often. I'm wanting to free up HP, but i don't want to do it by sacrificing engine cooling. OATs here in Granbury right now are around 100-105, so keep that in mind as well. how does the 8100 like e-fans? are they sufficient? any other 8100 owners on here w/ efans? thanks in advance-
Old Aug 15, 2006 | 03:05 PM
Whippled 496's Avatar
The Dmax radiator and the 8.1L radiator are not the same size. the 8.1L radiator has a 37" core, almost 44" end to end. Its about 3" longer than the Dmax radiators.
Old Aug 16, 2006 | 07:49 AM
8.1 HD's Avatar
Look up TByrne...he is one of the only guys I know that put e-fans on the 8.1, I thought about it, but am still not sold on them.
Old Aug 16, 2006 | 09:16 AM
TieRod's Avatar
TByrne has one for a 6.0 and he said they did fine. I'm sure the D-Max fans will be better suited for the 8.1.
Old Sep 7, 2006 | 12:06 AM
Had e-fans on mine, worked great never really did any heavy towing though.
On mine I designed my own plate and waterjetting it out of alum. Then mounted 2 3300 cfm fans with a DCControl fan control unit. The only problem was, the fans that I bought were a junk brand(ZIRGO) and were out of balance. So you felt the fans spooling up.
I talked to the guy who sold me the fan control, I should of went with 2 Lincon Mark VIII fans. these are known to pull 4300 cfm min each!!
thunder550
Oct 8, 2015 04:53 PM
old motorhead
Sep 29, 2015 08:22 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
2000_Silverado_SS
Sep 18, 2004 09:02 AM
boomer 33
Jun 16, 2004 10:37 AM
