Vortec 6.0 to LS2 conversion.
Old Sep 6, 2006 | 04:33 PM
kukri's Avatar
Default Vortec 6.0 to LS2 conversion.
Hello,
I have a couple of questions. The Vortec 325 hp that comes in Hummer H2 is a 6.0, so is LS2. What are the differences besides the aluminum/iron block, cam and heads? Can Vortec 6.0 be converted to an iron block LS2 just by swapping heads and cam? Do LS6 heads flow more than LS2 heads? Does LS6 cam make more power than LS2 cam? Could LS6 cam and heads be put on the 6.0 Vortec without problems?
Thank you,
Roman.
Old Sep 6, 2006 | 04:53 PM
Nick™'s Avatar
here's some good info for you:
http://www.gmhightechperformance.com..._look_feature/
Old Sep 6, 2006 | 04:56 PM
Badass61''s Avatar
The ls2 is a gen IV engine. lq4/9 is a gen III. The ls2 and ls6 heads are the same as the lq9 heads from what i know and flow the same ammount. except the chambers are bigger and they will lower the compression ratio when bolted on. I'll let everyone else fill in the blanks or correct me
Old Sep 6, 2006 | 05:11 PM
dirt track racer 81's Avatar
ls2 oil filter is up front instead of the back..you would need to make a pan for it to fit the trucks..or the ls2 oil pan could fit i may be wrong but i know there in different locations
Old Sep 6, 2006 | 05:56 PM
Quik's Avatar
5 year bitches!
a LS2 is nothing more then a LQ9 with 243 heads to bump the compression up. but you have a LQ4 so its not the same. strenght in internals is different also
Old Sep 6, 2006 | 06:16 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
With an aluminum block and relocated knock sensors
Old Sep 6, 2006 | 06:39 PM
kukri's Avatar
Thank you for the replies.
Well in that case, what would that 6.0 make with LS6 cam and LS2/LS6 heads to the motor?
Old Sep 6, 2006 | 06:51 PM
1slow01Z71's Avatar
damn close to 400 at the crank
Old Sep 7, 2006 | 12:49 AM
Quik's Avatar
5 year bitches!
sorry about that but ppl now get the point
Old Sep 7, 2006 | 02:44 AM
icedenali's Avatar
I have ported Heads from WestCoastRacing(Richard) with LS6 Cam, At high RPM after 30mph, My Yukon Denali pulls like train, it's weighted at 5800lbs. you'll definately feel the power at top END.
You'll also need tranny mods.
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
gmcyukon
Oct 5, 2015 06:20 AM
trxmxzx
Sep 29, 2015 07:42 AM
sTNT971
Sep 26, 2015 04:22 PM
