Here Is A Tip For Colder A/c......
Old Jun 14, 2005 | 09:40 PM
  #21
14 Second Truck Club
Originally Posted by PSWired
The previous owner had done that to my pickup when i got it- the home depot ball valve mod.
On a side note, the OBS SUVs have a heater bypass valve that does this same thing, that's controlled by the HVAC control module. Wonder why the SUVs get this but the pickups don't?
I had an old Caprice and Mote Carlo with the valve. It would stick in the winter leaving me with no heat, just ended up removing it or rigging it open.
Old Jun 14, 2005 | 09:42 PM
  #22
onyx's Avatar
i'll have to try this... TUCSON, AZ....
Old Jun 14, 2005 | 10:24 PM
  #23
white1's Avatar
Gets hot in La. (the state) also. With 105% humidity and no rain (don't ask I don't understand eigthor just following the weatherman) 97* is pretty damn hot. Its gotten to 92* already. I think I'll be trying this, just cap off the heater core. Thanks for the tip.
Old Jun 15, 2005 | 12:12 PM
  #24
desTRUCKtive's Avatar
Originally Posted by 02CHEVYRACING TRUCK
i feel that my ac runs hotter with the e-fans aswell, but in TX when it reads 95 its really 105!!!!
The reason why the A/C is hotter with the Efans is becuase the clutch fan is cooling the condenser all the time by running air through it all the time. The fans are not on all the time so this will cause the condenser to be a little warmer. This is why it is nessecarry for the fans to turn on when the clutch goes on.
But this is a good idea here I am going to have to try it. Should be 105 today, and it is feeling a little humid.
Old Jun 15, 2005 | 12:31 PM
  #25
white1's Avatar
Yea I learned that the hard way. At first I didn't have mine set up to turn on with the A/C. It was like a sauna till you were rolling. Damn 134a.
Old Jun 15, 2005 | 03:56 PM
  #26
BLACK 5.3's Avatar
well to show you how simple this mod is i have attached a pic for anyone who doesn't know what im talking about.. if it works for ya then go ahead and install the valve...
PS.... took this pic just before cleaning engine bay
Attached Thumbnails Here Is A Tip For Colder A/c......-111222.jpg
Old Jun 15, 2005 | 04:27 PM
  #27
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
I need to do this, the A/C in my Crewcab sucks!
Old Jun 15, 2005 | 04:33 PM
  #28
PSWired's Avatar
Electric fans should be wired to run whenever the AC compressor is engaged. If you have the PCM controlling the fans you can have them run only when below a certain vehicle speed if the AC is on, since natural airflow over the condensor at speed eliminates the need for the fans.
Old Jun 15, 2005 | 04:34 PM
  #29
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Yeah that engine bay is a little dirty. I think I see an sc in the corner though.
Old Jun 15, 2005 | 05:40 PM
  #30
BLACK 5.3's Avatar
yeh real dirty rite now i need to get one of those hand held high pressure steem cleaner things from the "as seen on tv" commercials
