Help getting fan clutch off
Old Jul 31, 2009 | 08:50 PM
ihdude's Avatar
Default Help getting fan clutch off
Is the fan clutch nut a standard turn or is it backwards? Any pointers on how to get it off? Not have much luck with it. Thanks
Old Jul 31, 2009 | 09:02 PM
eallanboggs's Avatar
Big wrench and a 3lb maul.
Old Jul 31, 2009 | 09:20 PM
LSGUNSS's Avatar
formerly 2000blackcamaross (6-25-2013)
+1 on the bi wrench and a BFH
I also put a pry bar in between the belt and pulley because I was going put a new belt on after.
Old Jul 31, 2009 | 11:34 PM
bolikes2skate's Avatar
forgot what way to turn it but see what direction it spins when its cranking over and thats the direction you need to spin the wrench jus use a lil wd40 should come right off with at least a foot long wrench
Old Aug 1, 2009 | 06:39 AM
neilownz's Avatar
I used a 18" adjustable wrench with a fist maul. A pipe wrench will even work in a pinch.
Old Aug 1, 2009 | 08:24 AM
SnakeOiler's Avatar
that's what I did. Took about 3-5 hits.
lefty loosey
Old Aug 1, 2009 | 08:33 AM
droppedchev's Avatar
i think its standard thread if i remember
Old Aug 1, 2009 | 12:01 PM
ihdude's Avatar
How are you keeping the pulley from turning? The belt is not holding it. Should I get a new belt and then try to break the fan loose?
Old Aug 1, 2009 | 03:13 PM
chiliz666's Avatar
the threads are standard threads. what i did was take the belt off, use a small pipe wrench leaned up against the front part of the motor so it wouldn't move then used a crescent wrench.
Old Aug 1, 2009 | 05:45 PM
ihdude's Avatar
I finally got it off. Thanks for the tip on turning the way the fan turned. I used a pry bar to hold the pulley and had a buddy use a crescent wrench and a hammer. Couple of licks and it broke free.
Wolftrk99
Dec 3, 2015 08:12 PM
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Shotguntommy
Sep 15, 2015 05:24 AM
