harmonic balacer Sh*t itself HELP!! PICS.
Old Feb 16, 2011 | 11:47 PM
  #31
Bumpers's Avatar
I always use a new bolt.. Yea the stocker might work or it might snap when your torquing it down or just come loose. I would rather be safe then sorry cuz I really not a fan of pulling engines out
Old Feb 16, 2011 | 11:50 PM
  #32
AKlowriderZ71's Avatar
11 Second Hall Moniter
^^^ Says the guy who can't decide lifted or lowered..... haha!!
Old Feb 16, 2011 | 11:52 PM
  #33
budhayes3's Avatar
PT's Slowest Truck
...not to mention that you've already had a problem with the balancer coming loose, and it looks like you dodged a bullet as the crank looks OK in the pics. The bolt looks fine in the pics also, but why take the chance in this case especially?
Old Feb 17, 2011 | 12:10 AM
  #34
Bumpers's Avatar
Lifted .. Final answer
Old Feb 17, 2011 | 09:21 PM
  #35
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
should go back down with the stock GMC 20s & just a tad of Texas rake, IMO
Old Feb 17, 2011 | 09:57 PM
  #36
CashDudeHomie's Avatar
I would NEVER reuse the stock TTY bolt, and I would never use locktite on it. Install the pulley with the special tool/torch/longer bolt, then tighten the pulley with the old bolt, then torque down the new bolt and go an additional 110* or however many the manual calls for. I use a 4 foot cheater pipe.
But there are plenty of other things that I do half-***, so I won't preach too much
Old Feb 17, 2011 | 10:00 PM
  #37
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I went with a 20$ ARP bolt mainly due to the fact that Ive read of a few people on tech breaking brand new bolts tq'ing them to spec and I didnt want to chance that.
Old Feb 18, 2011 | 09:18 AM
  #38
LaCamionetaGris's Avatar
well i'm gonna buy a new bolt a less than $5 bucks its a no brainer, i'm install the stock pulley saturday. so what is the right way to install this thing. personally i use the install tool that presses it in and then tighten down the bolt jst w/ my HEman strength...
Old Feb 18, 2011 | 10:08 AM
  #39
dirt track racer 81's Avatar
Use an install tool to press it on. Tightening it by hand is not tight enough.
Old Feb 18, 2011 | 10:11 AM
  #40
budhayes3's Avatar
PT's Slowest Truck
I believe that the factory procedure is to put the old bolt in and tighten it to 240 ft/lb, then remove, install the new bolt and tighten to 37 ft/lb, then turn it another 140* to tighten and stretch the bolt. IIRC, the last time I did mine I couldn't get the whole 140* but the bolt was effin tight and hasn't given me a problem with over 40k on it
